Changing standard error to standard deviation.
The discussion focuses on converting the Standard Error of the X coefficient in regression analysis to Standard Deviation. The user proposes the formula STD DEV = (STD ERROR) / (degrees of freedom)^0.5, but clarifies that the correct relationship is STD ERROR = STD DEV / (n^0.5). Additionally, the user emphasizes that degrees of freedom is not synonymous with sample size, "n," and introduces an alternative formula for Standard Deviation as STD DEV = SUM OF SQUARES / ((n-1)^0.5).
  • Understanding of regression analysis and coefficients
  • Familiarity with statistical concepts such as Standard Error and Standard Deviation
  • Knowledge of degrees of freedom in statistical contexts
  • Basic proficiency in mathematical formulas and calculations
  • Research the relationship between Standard Error and Standard Deviation in regression analysis
  • Learn about degrees of freedom and its application in statistical tests
  • Explore the calculation of Standard Deviation using the SUM OF SQUARES method
  • Investigate common misconceptions in statistical terminology
Statisticians, data analysts, and anyone involved in regression analysis who seeks to clarify the relationship between Standard Error and Standard Deviation.
operationsres
Hi all,
I've done a regression and have the Standard Error of the X co-efficient (i.e. the slope).
How do I change this figure to the standard deviation?
Is the formula
STD DEV = (STD ERROR)/(degrees of freedom)^0.5
Where degrees of freedom = N - number of X coefficients.
Thanks.
Actually, I believe the formula is STD ERROR = STD DEV / (n^0.5)
Moreover:
I'm reluctant to use the term "degrees of freedom" because this measure doesn't come into play unless a statistical test is involved, and is not the same as the sample size, "n."
  • · Replies 24 ·
  • · Replies 37 ·
