Einstein and Lenard in Bad Nauheim
  • Context: Graduate
  • Thread starter Thread starter Histspec
    Einstein
The discussion revolves around the Bad Nauheim debate (1920) between Albert Einstein and Philipp Lenard, focusing on Lenard's criticisms of relativity. Key points include philosophical implications, the nature of forces in different frames, and the interpretation of physical processes. Participants explore the implications of these criticisms within the context of both relativity and classical physics.
  • Philosophical exploration
  • Lenard argues that every physical process must have an "illustrative" explanation in the aether, contrasting it with mathematical explanations.
  • Lenard claims that only forces produced by masses can exist, rejecting the concept of fictitious gravitational forces in accelerated frames.
  • Lenard suggests that in rotating frames, the speed of light is not constant, proposing that the universe rotates with superluminal velocity when considering Earth at rest.
  • Einstein counters that "illustrative" explanations are subjective and have evolved over time, thus cannot determine the correctness of a theory.
  • Einstein asserts that the so-called fictitious forces are due to distant masses, referencing Mach's principle.
  • Einstein acknowledges that the speed of light is not constant in rotating frames but maintains that general relativity has different rules governing light speed compared to special relativity.
  • Some participants question the clarity of Lenard's terminology, particularly regarding "images of the first and second kind," suggesting possible translation issues or misstatements.
  • There is a discussion about the philosophical implications of understanding physical theories, with references to historical figures like Lord Kelvin and Pierre Duhem.
  • One participant expresses concern about discussing Lenard's later views, suggesting they deviate from scientific rigor.
Participants express differing views on Lenard's criticisms and their implications for relativity. Some argue that Lenard's points do not contradict the theory, while others emphasize the philosophical and interpretative challenges they present. The discussion remains unresolved regarding the validity and impact of Lenard's arguments.
Participants note that the terminology used by Lenard may have been imprecise or misinterpreted, leading to confusion about his criticisms. The debate also touches on the broader philosophical implications of scientific understanding and model-building.
This discussion may be of interest to those studying the history of physics, the philosophy of science, or the development of relativity, as well as individuals exploring the interplay between scientific theories and their interpretations.
Histspec
After reading the Bad Nauheim debate (1920) between Albert Einstein and http://en.wikipedia.org/wiki/Philipp_Lenard" , there are three critical points raised by Lenard against relativity (see also the following descriptions of the debate by Hermann Weyl, Gehrcke, Körner):
http://en.wikisource.org/wiki/The_Bad_Nauheim_Debate
a) That for every physical process there must be a corresponding explanation in the aether, that is, there must be an "illustrative" explanation by "images of the second kind", as opposed to mathematical explanations by images of the "first kind".
b) Only forces that are produced by masses can exist, but not the fictitious gravitational forces in the accelerated frames of general relativity. Therefore, in the case of a decelerating train, it is in fact the train that accelerates, not the environment.
c) That in rotating frames the speed of light is not constant, for example, when the Earth is considered at rest, than the universe is rotating - especially at its rim - with superluminal velocity.
Einstein's response:
a) What we call "illustrative" or "common sense" has changed in time, and therefore it cannot be regarded as a criterion of the theory's correctness.
b) He argues that the "fictitious" gravitational forces in accelerated frames are the products of the "distant masses". (Einstein evidently was alluding to Mach's principle.)
c) He says that in rotating frames the speed of light is indeed not constant, but this is no problem as in general relativity other rules for the speed of light apply than for special relativity.
It's notable, that Lenard (who never understood relativity) became a member of the Nazi party, and was the founder of the racist http://en.wikipedia.org/wiki/Deutsche_Physik" .
Regards,
I'm wondering if there was a mistake in translation, or if Lenard simply misspoke here: "For example, Mr. Weyl spoke in terms of images of the first kind, as he expressed all processes by equations. By images of the second kind, the equations can be interpreted as processes in space."
I suspect he meant to say "...as he expressed all phenomena by equations" [rather than "processes"]. The whole idea, if I understand the debate correctly, was that "images of the first kind" were highly abstract, with no process in mind at all, whereas images of the 2nd kind were mathematical descriptions of real, ongoing processes (interactions of lots of tiny, visualizable objects). But the way it is translated here seems to make images of the 1st kind the same as those of the 2nd kind (both being expressions of processes).
The first is philosophical, the other two would apply to Newtonian physics as well (inertial vs. non-inertial frames) and it's not clear what the problem is.
I hope, we won't discuss Lenard's idiosyncrasic ideas on PF. It's one of the sadest examples of a great scientist becoming completely off the scientific track in his later years. It's also an example for being careful with "anti-mathematicians" ;-).
Any thoughts on whether the translation was bungled, or if he (Lenard) misspoke?
I'm not sure that question is meaningful; an imprecise thought cannot be precisely translated. Conversely, with Einstein's prose it's often hard to tell whether you're reading English that he wrote himself or a good translation from German; either way it's striking for its precision.
I'd like to get a transcript of the original German, and have some German-speaking scientists I know translate it. But, it seems no such transcription exists.
I believe Lenard was expressing a thought along the lines of what had long been argued by the likes of Lord Kelvin and Ludwig Boltzmann - that one cannot be said to understand something unless one is able to make a model of it in one's mind (a model of the interactions of 3D objects), and against the view of those who scoffed at the mechanical worldview, such as Pierre Duhem (a vehement energeticist and devout Catholic, who thought such deep speculations were inappropriate for science, and the realm of theology). Duhem detested the 19th century British habit of model-building, despite its great success with Maxwell and company. Duhem was quite influential with Einstein and others of his era.
Basically, though, I think the distinction is between totally abstract mathematics (unvisualizable) and mathematics that describes the workings of a visualizable process.
These are "critical points" in the sense that he is critical of relativity and these are his points. They are not "critical points" in the sense of a point of failure that is critical for the structural integrity of the theory. Basically, I think all three can be accepted without in the least contradicting the theory.
Both views are wrong. The ability to visualise a theory well is neither necessary nor inappropriate for science.
  • · Replies 28 ·
  • · Replies 219 ·
17K
  • · Replies 52 ·
  • · Replies 75 ·
