Question about necessary concentration of urea for radish growth
The discussion revolves around the effects of urea concentration on the growth of radish plants in a controlled experiment. Participants explore the appropriate concentration levels of urea to use, given the constraints of a smaller scale experiment compared to previous studies.
  • Homework-related
  • One participant outlines their experimental design, indicating the use of urea as a nitrogen fertilizer and a control group with no treatment.
  • Another participant suggests varying the urea concentrations across multiple test groups, proposing to include higher and lower concentrations than those used in the referenced study.
  • A later reply clarifies the limitation of having only 24 plants total, proposing a division of plants into a control group and a test group with different concentration levels.
  • One participant expresses concern about the negative effects of excessive urea, seeking information on the consequences of high nitrogen levels on plant health.
Participants do not reach a consensus on the specific concentrations of urea to use, and there is uncertainty regarding the effects of high nitrogen levels on plant growth.
Participants mention limitations related to the number of plants available for experimentation and the need for more information on the effects of nitrogen on plants, indicating a lack of clarity on optimal urea concentrations.
Millacol88
I have a project in my grade 11 biology class to design a controlled experiment showing how some factor affects plant growth, specifically radishes. I have decided to add urea as a nitrogen fertilizer to one group and do nothing to the other leaving all other factors the same between the two groups.
I have found this pdf: http://www.fspublishers.org/ijab/past-issues/IJABVOL_6_NO_3/19.pdf
This experimentation shows a significant increase in plant height, root length, and number of leaves when the plants were enriched with urea. The concentrations of urea are given.
My experiment, however, will be on a much smaller scale. I am growing 24 plants, each in its own individual compartment, around 4cm long by 4cm wide by 5cm deep. I need to know if I can use the same concentration of urea as was used in the study I linked to.
Biology news on Phys.org
It might be better to vary your concentrations with say 5 or 6 plants in each experimental concentration group. For instance try it with their concentration, double their concentration and half their concentration (and a control group with none).
I'm sorry, I should have clarified that I only have 24 radish plants to grow in total. That's including the test group and the control. I could try a twelve-plant control and a twelve plant test group, with that test group split up into three different levels of concentration. I'm still not sure what those concentrations should be.
Sorry to bump a thread, but I killed one of my test groups with too much urea, and I'm struggling to find any information about what specifically too much of a nitrogenous compound does to plants. Could anybody point me to a source that has anything on this?
  • · Replies 21 ·
  • · Replies 59 ·
13K
11K
