What is the Time to Slide 10m After Falling from a Truck?
  • Thread starter Thread starter angel1410
The problem involves a box that falls from a truck and slides on the ground, with the goal of determining the time it takes to slide the last 10 meters before coming to rest. The context includes concepts from kinematics and uniform acceleration.
  • Participants discuss the use of kinematic equations to solve for time and question the appropriateness of the equations and variable substitutions. There is an emphasis on determining the speed of the box after it has traveled a certain distance before calculating the time for the final segment of the slide.
The discussion includes various attempts to apply kinematic equations, with some participants expressing uncertainty about their calculations and the correctness of their approaches. A suggestion was made to calculate the speed after traveling 35 meters to facilitate finding the time for the last 10 meters.
Participants are working with given values such as initial speed, acceleration, and displacement, while also addressing potential misunderstandings regarding units and the nature of the quantities involved.
angel1410
A box accidentally falls from the back of a truck and hits the ground with a speed of 15m/s[Forward]. It slides along the groud with uniform acceleration for a distance of 45m before coming to rest. Determine the time it takes to slide the last 10m
v2=v1+a t
displacement=vi x t + 1/2 acceleration x t^2
displacement=v1 +v2 /2 x time
surely you can give it a try ! :), state the givens you have there
Well, i tried with the equation displacement=v1 x time + 1/2 (acceleration) (time)^2
but i am not sure if i am using the right equation and subbing in the variables right.
I subbed in: v1=15m/s acceleration=-2.5m/s^2 displacment=10m v2=0
and I got the answer 11.29m but i am not sure if its right. HELP!
The question is, How much time does it take the box to travel it's last 10m before coming to rest?
The answer you gave is 11.29m.
That's not a quantity of time.
You need to determine how fast the box is moving after it travels 35m, which is when it has 10m left to travel.
Then you can determine how much time it takes to travel from that speed to 0m/s.
vf2 = vi2 + 2ax
0 = 225 -2 x a x 45 ( Box becomes rest finally. So the acceleration is negative )
a = 2.5 m/s2 in opposite direction
x = vit + at2/2
35 = 15t - 2.5t2/2
28 = 12t - t2
t = 6 - 2[tex]\sqrt{2}[/tex] sec.
similarly,
Total time T = 6sec.
Time taken to cover last 10m = 6 - 6 + 2[tex]\sqrt{2}[/tex]
[tex]\approx[/tex] 2 x 1.41
= 2.82 sec.
Is it correct?
Perfect!
  • · Replies 38 ·
