Do Photons Spin in Our Reference Frame?
  • Context: Undergrad
  • Thread starter Thread starter scope
    Photons Spin
The discussion centers around the concept of photon spin, particularly in relation to reference frames and the implications of special relativity. Participants explore the nature of angular momentum in massless particles like photons and the transformation of spin under Lorentz transformations.
  • Some participants assert that photons must possess angular momentum due to their lack of rest mass.
  • One participant questions whether photons can be observed as spinning in our reference frame, given the principles of special relativity.
  • Another participant mentions that photons have two possible values of spin projection in quantum field theory (QFT), specifically h/2π and -h/2π, and not 0.
  • There is a discussion about the implications of Lorentz transformations on spin, with one participant suggesting that the concept of helicity may be more appropriate for massless particles like photons.
  • One participant elaborates on the gauge symmetry in quantum electrodynamics (QED) and how it leads to the elimination of one polarization degree of freedom, resulting in two physical polarizations for photons.
  • Another participant notes that the polarization parallel to the momentum is not applicable for massless photons, as they cannot be at rest.
Participants express uncertainty regarding the visibility of photon spin in a given reference frame and whether the concept of spin or helicity is more appropriate for massless particles. There is no consensus on these points, and multiple competing views remain.
Limitations include the dependence on definitions of spin and helicity, as well as unresolved aspects of how spin transforms under Lorentz transformations. The discussion does not reach a definitive conclusion on these matters.
scope
hi,
i have read that photons must have an angular momentum because they have no rest mass. does anyone there understand why?
Where did you read this? And what exactly did it say?
sorry, i don't know, for example the two possible values of the spin projection of photon in QFT are h/2pi and -h/2pi, and not 0.
i do wonder about the spin of the photon. in OUR reference frame, do we see the photon spinning or not, if we apply special relativity?
by the way how does spin transform under Lorentz transformations?
I would be grateful for any reply
Consider a photon flying in the direction of z-axis. Any vector massive particle can have 3 spin states - however one of them requires the z component of momentum to be 0 (particle in rest). Photon can not be in rest, so only 2 spin states remain.
The polarization parallel to the momentum is ruled out because photons are massless. You cannot go to their rest frame.
This can be understood in QED in the following way: QED has a U(1) gauge symmetry which allows you to eliminate one gauge degree of freedom. Let's keep things as simple as possible and set A°=0= use the (time-gauge; now we have eliminated one polarization.
A°=0 is a rather good choice as A° is not a dynamical degree of freedom b/c its conjugate momentum is zero; therefore it acts as a Lagrange multiplier genarating a constraint. This constraint is the Gauss law G which again must be set to zero, i.e. G=0. In addition the Gauss law generates time-independent gauge transformations which respect the A°=0 gauge, that means gauge transgformations where the gauge function is time-independent.
Via this residual gauge symmery or (which is more or less the same) via the solution of the Gauss law constraint another degree of freedom can be eliminated leaving us with to physical polarizations of the photon.
If we would introduce a mass term in the Lagrangian gauge invariance would be broken and the A°=0 gauge would no longer be allowed (so the first elimination does no longer work). But A° is still a Lagrange multiplier, the - now modified - Gauss law G'=0 would still be solved for and the second elimination would go through leaving us with three degrees of freedom.
The Lorentz group has a rather complicatedstructure. In principle it is something like SO(3,1), but one must use the complexification / the universal covering group Spin(4) which is (locally) the same as SU(2)*SU(2). Now every SU(2) has integer and half-integer representations leaving us with two series like 0, 1/2, 1, 3/2, ... E.g. the Dirac equation uses 4-spinors (which are bi-spinors) transforming as (1/2, 1/2) using two 2-spinors, one from each series.
For massless particles the situation is slightly different and I think it's etter not to use spin but helicity.
  • · Replies 17 ·
  • · Replies 33 ·
  • · Replies 38 ·
