Angle for Maximum Range in Projectile Motion with Drag Equation?
The discussion focuses on solving problem 3.8 from Kibble & Berkshire, specifically determining the angle for maximum range in projectile motion while accounting for drag. The user successfully derived the first-order approximation of the range but struggles with maximizing the range angle, \(\alpha\). The key equations referenced include \(v^2 = u^2 + w^2\) and the expression for range \(x\), which incorporates drag represented by \(\gamma\). The user is advised to express \(u\) and \(w\) in terms of \(v\) and \(\alpha\) to facilitate extremization of \(x\) with respect to \(\alpha\).
  • Understanding of projectile motion principles
  • Familiarity with Kibble & Berkshire textbook, specifically equations from pages 53 and 68
  • Knowledge of calculus, particularly optimization techniques
  • Basic grasp of drag forces in physics, represented by the parameter \(\gamma\)
  • Study the derivation of the range formula in projectile motion with drag
  • Learn how to apply optimization techniques to functions of multiple variables
  • Explore cubic equations and their solutions in the context of trigonometric functions
  • Investigate zeroth-order approximations in physics problems involving small angles
Students and educators in physics, particularly those focusing on mechanics and projectile motion, as well as anyone tackling advanced problems involving drag forces in motion.
fluxions
The problem is Kibble & Berkshire 3.8, http://books.google.com/books?id=0a...kibble berkshire&pg=PA68#v=onepage&q&f=false" is a link. (The problem is on page 68. Equation 3.17, referred to in the problem, is on page 53.)
I figured out the first part (finding the first-order approximation of the range), but I'm having problems figuring out the angle for maximum range.
Edit: I originally said it was problem 3.7, but it's really problem 3.8 I'm having problems with. The link is still valid.
The velocity is v^2 = u^2 + w^2 (see page 53). The angle we're looking for is \alpha = arctan(w/u).
It seems like one should be able to write the expression for x in terms of v, and find the extrema of that function. However it is impossible to write x solely in terms of v (and some constants). Also, I don't really understand the hint. Halp!
You can certainly express u and w in terms of v and [tex]\alpha[/tex]. You can then extremize x with respect to [tex]\alpha[/tex]. As for the hint, if you keep all terms in [tex]\alpha[/tex], you arrive at a cubic equation for [tex]\sin\alpha[/tex], which is a bit unwieldy. However, any way that I try to use the hint, I'm always off by a numerical factor from their result for [tex]\cos 2\alpha[/tex]. Maybe you'll have better luck.
Still stuck on this problem.
I can write, using the expression for x given in the link and the relation between u,v,w, and alpha
[tex]x = \frac{2}{g} v^2 \sin\alpha \cos\alpha - \frac{8 \gamma}{3 g^2} v^3 \cos\alpha \sin^2\alpha[/tex]
Maximizing this function wrt. to v doesn't lead to the desired answer (I'm omit the details).
So I try to use the hint("in the term containing \gamma, you may use the zeroth-order approximation for the angle") Ok, so for \alpha small, the zeroth order approx. of cos(\alpha) is 1 and the zeroth-order approx. of sin^2(\alpha) is ... 0? This doesn't make sense. And clearly it leads nowhere.
Maybe I'm supposed to leave the sin^2 term alone. If I try that, I still don't get the desired answer.
Any insight into how to solve this problem is appreciated.
  • · Replies 25 ·
28K
