What is the tension in the cable problem.
  • Thread starter Thread starter Dominic
    Cable Tension
The tension in the cable problem involves calculating the force exerted on a cable towing an 800-kg car along a 20-degree slope at a 30-degree towing angle. The formula used is T = mg(sinθ - cosφ), where T is the tension, m is the mass of the car, g is the acceleration due to gravity (9.8 m/s²), θ is the slope angle, and φ is the towing angle. Substituting the values into the formula yields a tension of approximately 7,836 N. This calculation assumes no resistive forces such as friction or air resistance.
  • Understanding of basic physics concepts, specifically forces and tension.
  • Familiarity with trigonometric functions, particularly sine and cosine.
  • Knowledge of Newton's laws of motion.
  • Ability to perform calculations involving angles and vectors.
  • Study the effects of resistive forces on tension calculations in towing scenarios.
  • Learn about vector decomposition in physics for analyzing forces on inclined planes.
  • Explore advanced applications of tension in different mechanical systems.
  • Investigate the role of friction in towing dynamics and its impact on tension calculations.
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of towing systems and force calculations on inclined planes.
Dominic
An 800-kg car is being towed with a constant speed along a slope. What is the tension in the cable? Neglect all resistive forces. The slope it is on is 20 degrees and the angle that the truck is towing at is 30 degrees.
The roadway is supporting part of the weight of the car- the component of the "weight vector" perpendicular to the roadway. If the roadway were flat, that would be the entire weight and there would be tension in the cable only when accelerating. Since the roadway is at 20 degrees, take the weight of the car (downward) and find components perpendicular to and parallel to the roadway. The cable has to support the component parallel to the roadway.
The force parallel to the road way is one leg of a right triangle with the tow cable as hypotenuse. Since you know the angle is 30 degrees, you can calculate the "length of the hypotenuse" (the tension in the cable).
The tension in the cable problem refers to the force exerted on the cable that is pulling the car along the slope. In this scenario, the tension in the cable is affected by the weight of the car, the angle of the slope, and the angle at which the truck is towing the car.
To calculate the tension in the cable, we can use the formula T = mg(sinθ - cosφ), where T is the tension, m is the mass of the car, g is the acceleration due to gravity, θ is the angle of the slope, and φ is the angle at which the truck is towing the car.
In this problem, the mass of the car is 800 kg, the acceleration due to gravity is 9.8 m/s^2, the slope angle is 20 degrees, and the towing angle is 30 degrees. Plugging these values into the formula, we get T = (800 kg)(9.8 m/s^2)(sin 20° - cos 30°) = 7,836 N.
Therefore, the tension in the cable is approximately 7,836 N in this scenario. It is important to note that this calculation neglects any resistive forces, such as friction or air resistance, which may affect the actual tension in the cable.
  • · Replies 19 ·
  • · Replies 19 ·
