Is the Product of Expectation Values Always True in Quantum Mechanics?
The discussion centers on the conditions under which the product of expectation values in quantum mechanics holds true, specifically examining the equation \(\langle\psi|AB|\psi\rangle=\langle\psi | A|\psi\rangle\langle\psi |B|\psi\rangle\). Participants explore the implications of this equation in relation to the independence of operators and the nature of quantum states.
  • One participant notes that the equation holds true if \(|\psi\rangle\) is a normalized eigenstate of both operators \(A\) and \(B\).
  • Another participant suggests that while the equation implies that the operators commute, it does not necessarily hold for all states, even if \(A\) and \(B\) are Hermitian observables.
  • A further contribution indicates that the requirement for the equation to hold for general states involves a specific relationship between the coefficients of the state expansion, which complicates the matter.
  • It is mentioned that the equation implies uncorrelated operators, suggesting no Heisenberg uncertainty in simultaneous measurements of both observables.
  • One participant points out that commuting operators do not guarantee the equation, using the example of the expectation value of \(A^2\) to illustrate this point.
Participants express differing views on the conditions necessary for the product of expectation values to hold, indicating that the discussion remains unresolved with multiple competing perspectives.
Participants highlight the dependence on the specific nature of quantum states and the operators involved, as well as the implications of commutation relations, which remain unresolved in the discussion.
daudaudaudau
In quantum mechanics, when is this true
[tex] \langle\psi|AB|\psi\rangle=\langle\psi | A|\psi\rangle\langle\psi |B|\psi\rangle[/tex]
? In probability theory, when the two variables are independent, the mean value of the product is the product of the mean values. What about QM?
It is true if [itex]|\psi\rangle[/itex] is a normalized eigenstate of both A and B because then
[tex] \langle \psi|AB| \psi\rangle=a_\psi b_\psi[/tex]
The equation
[tex] \langle \psi|AB|\psi\rangle = \langle \psi|A|\psi\rangle \langle \psi|B|\psi\rangle \ \forall \psi[/tex]
also leads to [A,B]=0. But assuming that [A,B]=0 and that both are usual Hermitian observables does not seem to imply the above equation for general states, even though any state can be expanded as a linear combination of common eigenstates: this would require
[tex] \sum_i a_ib_i|c_i|^2 = \sum_{i,j} a_i b_j |c_i|^2 |c_j|^2[/tex]
for
[tex] |\psi\rangle = \sum_i c_i |\psi_i \rangle.[/tex]
So I don't have an answer to your question but I wrote anyway :) But
[tex] \langle AB \rangle = \langle A \rangle \langle B \rangle[/tex]
of course means that in the particular configuration, the operators are uncorrelated and there is e.g. no Heisenberg uncertainty in measuring both observables "simultaneously".
Yeah, it is not enough for the operators to commute, because A commutes with A, but
[tex] \langle\psi|A^2|\psi\rangle\neq\langle\psi | A|\psi\rangle\langle\psi |A|\psi\rangle[/tex]
  • · Replies 21 ·
