Calculus Homework: Derivative of g(x) = x * sqrt(4-x) using Product Rule
The discussion revolves around finding the derivative of the function g(x) = x * sqrt(4-x) using the product rule in calculus. Participants are exploring the differentiation of the square root component and the application of relevant rules.
  • Participants discuss the use of the product rule and express uncertainty about differentiating the sqrt(4-x) term. There are attempts to rewrite the square root in exponential form, and questions arise about the correct application of the chain rule.
The conversation includes various attempts to clarify the differentiation process, with some participants providing hints and guidance. There is acknowledgment of the need to apply the product rule correctly, but no consensus on the final derivative has been reached.
Participants are navigating through potential misunderstandings regarding the derivative of sqrt(4-x) and the correct placement of brackets in their expressions. The discussion reflects a mix of confidence and confusion about the steps involved in the differentiation process.
Chaubin
Find the derivative of g(x)=x * sqrt(4-x)
I know I use the product rule, but I am not sure how to derive the sqrt(4-x) portion.
Welcome to PF!
Hi Chaubin! Welcome to PF! :smile:
(have a square-root: √ :wink:)
Chaubin said:
… I am not sure how to derive the sqrt(4-x) portion.
Hint: rewrite it as (4 - x)1/2 :smile:
What's another way to write sqrt(4-x), say... with exponents?
So, I take the quantity (4-x)^1/2 and turn it into (1/2)*(4-x)^-1/2? Is that it?
Remember the chain rule.
(try using the X2 icon just above the Reply box :wink:)
you've left out the coefficient of x :redface:
Ok, i think I finished it.
I ended up with (x/((2 * sqrt(4-x))) + sqrt(4-x)
no, that would work for √(x-4), but not for √(4-x)
(and your brackets are in the wrong place)
I know the derivative of sqrt(4-x) is -1/(2*sqrt(4-x)).
After this I get a bit foggy on the procedure.
I think I have to use the product rule f(x)*g(x)= f(x)*g'(x) + f'(x)*g(x)
In this case f(x) = x and g(x)= sqrt(4-x).
So it should be:
x*(-1/(2*sqrt(4-x)) + 1 * sqrt(4-x)
correct?
Hi Chaubin! :smile:
(just got up :zzz: …)
correct?
Yup! :biggrin:
  • · Replies 31 ·
