Help with these problems please
  • Thread starter Thread starter Lilly
The discussion focuses on the application of the Van der Waals equation and its relationship to the ideal gas law under specific conditions. It is established that the Van der Waals equation, represented as (P - a/V²)(V - b) = RT, simplifies to the ideal gas law at low pressures and high temperatures. Participants also discuss the implications of temperature on the momentum and impact frequency of argon gas samples at 27°C and 77°C, emphasizing the need for further exploration of related equations.
  • Understanding of the Ideal Gas Law
  • Familiarity with Van der Waals Equation
  • Basic principles of Thermodynamics
  • Knowledge of Gas Kinetics
  • Study the derivation of the Ideal Gas Law from the Van der Waals equation
  • Explore the concept of momentum in gas particles
  • Investigate the effects of temperature on gas behavior
  • Learn about the kinetic theory of gases and its equations
Students and professionals in chemistry, physics, and engineering fields, particularly those studying gas laws and thermodynamics.
Lilly
help...with these problems please!
hi, could someone please help me with these? i would really appreciate it!
1) We state that the ideal gas law tends to hold best at low pressures and high tempuratures.Show how the Van der Waal's equation simplifies to the ideal gas law under these conditions.
2) Consider separate 1.00 L samples of Ar (g), both containing the same number of moles, on at 27 degrees C and the other at 77 degrees C. Compare the change in momentum per impact and the number of impacts per second in the 2 samples.
Chemistry news on Phys.org
Hi lily.
Let me help you with the first question.
What is van der waals equation?{(P-a/V^2)(V-b)=RT}
What do a & b represent??Why did van der waal make these changes??
If you are still unable to solve it,Read : thermodynamics,Gas equation,Van der waals equation .
hope to have been of help.
Hello,
Thanks poolwin2001 for reminding Van der Waals' famous equation. Lilly, there has to be another equation in which pressure and impact-related values are present.
  • · Replies 60 ·
11K
13K
