Energy in Schrodinger’s Equation
  • Context: Graduate
  • Thread starter Thread starter exmarine
    Energy
The discussion revolves around the interpretation and implications of energy in Schrödinger’s equation, focusing on the definitions and roles of total energy, potential energy, and their relationship in quantum mechanics. Participants explore theoretical aspects, conceptual clarifications, and specific questions related to the equation's formulation and its implications in various scenarios, including tunneling and reference points for potential energy.
  • Some participants question why potential energy cannot be subtracted from both sides of Schrödinger’s equation, suggesting that it seems nonsensical.
  • Others assert that while potential can be subtracted, it alters the nature of the equation, indicating that it is no longer an eigenvalue equation.
  • There is a discussion about the representation of total energy E as a constant, with some arguing that this conflicts with the notion of E being the sum of kinetic and potential energy.
  • In tunneling scenarios, participants note that potential V(x) can exceed total energy E, leading to questions about how this is possible, with some suggesting that it implies negative kinetic energy.
  • Participants discuss the reference point for potential energy, comparing it to classical mechanics where zero potential is set for convenience, and question if the same applies in quantum mechanics.
  • Some assert that one can add any function to the potential without affecting the Euler-Lagrange equation of motion, indicating a degree of flexibility in defining potential energy.
  • The mathematical formulation of Schrödinger’s equation is presented, with emphasis on the roles of operators and eigenvalues, but without consensus on the implications of these formulations.
Participants express differing views on the treatment of potential energy in Schrödinger’s equation, with no clear consensus reached on several key points, including the implications of subtracting potential energy and the interpretation of total energy in various contexts.
Participants highlight that the interpretation of energy and potential in quantum mechanics may depend on specific definitions and assumptions, such as the normalization of wave functions and the conditions under which the equations are applied.
exmarine
I have dozens of physics textbooks, but still can’t get a decisive fix on the energies in Schrödinger’s equation. Start with the "total energy" E. It seems to usually be defined as the sum of the kinetic and the potential.
1. Then why can’t I subtract the potential from both sides of the equation. That doesn’t make any sense.
2. It is often displayed as a constant, i.e., not as a function of position like the potential V(x). Again it doesn’t seem like E could then be the sum of kinetic and potential.
3. In tunneling situations, the potential V(x) is said to be LARGER than the total E. So how can that be true?
My second question is about the reference point for the potential energy. In mechanics, we set zero potential wherever it is convenient, as the change seems to be the only important feature. Is the same true for the potential in Schrödinger’s equation? I notice that in electrostatics, the potential energy is usually set to zero at infinity. So are all the potentials between like charges (repulsive forces) positive and all the potentials between opposite charges (attractive forces) negative?
Someone please write a paragraph (or two or three!) on this? Thanks, I appreciate those on here who have the knowledge and patience to answer questions.
BB
exmarine said:
..."total energy" E. It seems to usually be defined as the sum of the kinetic and the potential.
You can...
Generally, conservation of energy does apply.
Classically you would say it has a negative potential energy. This is just one of the myriad wonders of quantum mechanics---wonders which our minds just weren't built for.
For the most part, yes. There are some additional things that need to be considered: e.g. the square of the wave-function must be normalizable (thus the potential generally needs to approach zero at infinity), etc etc.
It is the gradient of the potential that determines the direction of the force. [tex]F = - \nabla U[/tex]
Hi, BB.
You can, but it is not eigenvalue equation any more.
E is eigenvalue. E should be value so that the equation is eigenvalue equation.
For that kinetic energy should be negative, i.e. exponential damping of wave function occurs.
Regards.
If one can subtract the potential from both sides of the equation, then it can have no influence on the solution - is that not correct? Somehow I don't believe that.
You can add to the potential any function that will not change
the Euler Lagrange equation of the motion.
Full equation
[tex]\hat{H}\Psi(x,t) = \hat{E}\Psi(x,t)[/tex]
Where hats denote operators. If H is time-independent, we look for solutions of the form
[tex]\Psi(x,t) = \psi(x)\phi(t)[/tex]
So then we have
[tex]\left(\hat{H}\psi\right)\phi = \psi\left(\hat{E}\phi\right) = E\psi\phi[/tex]
Here, E is just a number. This gives us two individual equations to be solved.
[tex]\hat{E}\phi = E\phi[/tex]
[tex]\hat{H}\psi = E\psi[/tex]
Keeping in mind that operator E is always the time derivative with some factors, it's easy to solve the first equation.
[tex]\hat{E}\phi = i\hbar \frac{\partial}{\partial t}\phi = E\phi[/tex]
[tex]\phi(t) = e^{-i \frac{E}{\hbar}t}[/tex]
The second equation depends on specific form for H, and is usually written in this form.
[tex]\hat{H}\psi = \left(-\frac{\hbar^2}{2m}\frac{\partial^2}{\partial x^2} + V(x)\right)\psi = E\psi[/tex]
And that's your time-independent Shroedinger equation as you are used to seeing it.
  • · Replies 36 ·
  • · Replies 41 ·
