Is Quantum Entanglement the Key to Understanding Particle Measurements?
The discussion revolves around the implications of quantum entanglement in the context of particle measurements, specifically addressing the relationships between position and momentum of entangled particles after measurements are made. The scope includes conceptual exploration of quantum mechanics, the uncertainty principle, and the EPR paradox.
  • Some participants propose that measuring the position of one particle allows for the determination of the position of another particle, but this is contingent on specific conditions regarding their momenta.
  • Others argue that entanglement may disappear after a measurement is made, which would affect the applicability of subsequent measurements on the entangled particles.
  • A participant suggests that the actual values of position and momentum depend on the type of measurement performed, indicating that the results are not absolute but contingent on the measurement context.
  • There is a claim that the uncertainty principle does not necessarily deny the possibility of determining both position and momentum with certainty, which raises questions about the interpretation of quantum mechanics.
  • One participant mentions the EPR paradox and suggests that measuring one particle affects the state of the other, referencing Bell's inequality for further reading.
Participants express multiple competing views regarding the implications of measurements on entangled particles, with no consensus reached on the interpretation of the uncertainty principle or the nature of entanglement after measurements.
There are limitations in the assumptions made about the relationship between measurements and the state of entangled particles, particularly regarding the conditions under which entanglement is maintained or lost.
This discussion may be of interest to those exploring foundational concepts in quantum mechanics, particularly students and enthusiasts seeking to understand the nuances of entanglement and measurement theory.
LucasGB
I know this is probably an extremely simple question, but anyway...
I shoot two particles towards each other. They collide, and then go their separate ways. Then I measure the position of particle A with full precision. This will allow me to determine with full certainty the position of particle B. A friend of mine is sitting somewhere else, sees particle B flying by and thinks to himself "I'm kinda bored, I'm going to measure this particle's momentum". He does so, with full precision, and is thus able to determine the momentum of particle A, with certainty. We meet up later for drinks and discover that adding together what we discovered we have determined with full certainty the position and the momentum of both particles.
So what's wrong?
So what's wrong?
1. You cannot infer the momentum of A and the position of B unless the momenta of the colliding particles are exactly opposite in your (and yours friend) reference frame.
2. Assuming that the above is true, entanglement disappears after the first momentum measurement so your friend's result does not apply to your particle anymore.
3. It might be the case that the position/momentum of the particles, is not the same for both but the actual values depend also on the type of measurement performed on them.
4. There is nothing wrong with the determination with full certainty of the position and the momentum of both particles. You may think that uncertainty principle denies this possibility but in fact it does not.
What you have described is called the EPR paradox. The answer, however strange it might seem, is that by measuring the state of the first particle you have in fact affected the state of the other particle. For more reading look up Bell's inequality.
Thank you for both your replies.
2. Why would the entanglement disappear?
4. Isn't this exactly what the uncertainty principle is about?
Exactly the point.
LucasGB, you say "Then I measure the position of particle A with full precision. This will allow me to determine with full certainty the position of particle B."
Wrong ! What it allows you is to determine, not the position, but the result that would be found if, and only if the position of the other particle was immediately measured (QM postulate).
But if, in the meantime, the momentum of that particle is measured instead of the position, then the wave function is modified by the measurement, and you can no longer tell that if you measured the position of that particle, you would get the same result.
Wow, Quantum Mechanics is subtle. Thank you all for your help.
A little bit off-topic: what would you recommend as the best introduction to Quantum Mechanics? Is Griffith's book good?
  • · Replies 58 ·
  • · Replies 40 ·
  • · Replies 17 ·
