Reversible vs. pseudostatic processes
  • Context: Graduate
  • Thread starter Thread starter paweld
    Reversible
The discussion clarifies the definitions and distinctions between reversible, quasistatic, and pseudostatic processes in thermodynamics. A reversible process is defined as one where the system and environment can return to their initial states, while a pseudostatic process assumes thermal equilibrium is maintained during slow changes. Quasistatic processes are a subset of pseudostatic processes that can reverse direction with slight changes in external factors. The conversation emphasizes that the concept of pseudostatic is relevant in contexts where changes occur at a time scale slow relative to the system's internal dynamics.
  • Understanding of thermodynamic processes
  • Familiarity with concepts of thermal equilibrium
  • Knowledge of system dynamics and external factors
  • Basic principles of magnetic fields in thermodynamics
  • Research the implications of reversible processes in thermodynamic cycles
  • Study the role of thermal equilibrium in pseudostatic processes
  • Explore quasistatic processes in the context of gas expansion
  • Investigate the effects of magnetic fields on thermodynamic systems
Students and professionals in thermodynamics, physicists studying energy systems, and engineers working with thermal processes will benefit from this discussion.
paweld
I wonder whether a reversible process has to be quasistatic or at least
pseudostatic? (probably there exist some processes involving magnetic field
which are reversible but not pseudostatic).
Below I define what I mean by a reversible, quasistatic and pseudostatic process.
Reversible process - let's consider a process R in which initial state of the system
was a, initial state of the environment was b and final state of the system and
environment was a' and b' appropriately. If there exists a process which
changes the state of full system (considered system + environment)
form (a',b') to (a,b) the process R is said to be reversible.
Pseudostatic process - this is a process during which it may be
assumed that both the system and its surroundings maintain thermal equilibrium
(the changes are made sufficiently slow).
Quasistatic process - this is such a pseudostatic process that in any moment
if we slightly change some of the external factors which cause it (pressure,
magnetic field, ...) we can reverse its direction.
Thanks for any answers.
Science news on Phys.org
So, I think the notion of 'pseudostatic' is in the context of a time scale slow relative to the internal dynamics of the system. This is a thermodynamic concept, so you cannot talk about whether changes in magnetic fields are reversible or pseudostatic, because in that case you are presumably only considering a single degree of freedom. Heating materials, allowing gases to expand, (de)magnetizing ferromagnets- in these systems the notion of reversible and pseudostatic is applicable, because as you change the bulk thermodynamic properties (T, rho, M respectively), the internal dynamics of the system allow the multitude degrees of freedom of adjust accordingly to 'catch up' with these bulk changes and come back into equilibrium. This usually is not so slow, so a pseudostatic process is quite fast by human time scales.
  • · Replies 60 ·
11K
  • · Replies 21 ·
