Quadratic drag equation by partial fractions
The discussion focuses on solving the quadratic drag equation using partial fractions, specifically demonstrating the integration of the equation dv/(1 - (v^2/v_ter^2)) = g*dt. The final result derived is v = v_ter * tanh(g*t/v_ter). Users highlight the importance of verifying calculations and suggest that discrepancies in results may arise from the complexity of the natural logarithm function. The integration method using partial fractions is confirmed as a valid approach, with recommendations to double-check integration limits and calculations.
  • Understanding of quadratic drag equations
  • Familiarity with integration techniques, specifically partial fractions
  • Knowledge of hyperbolic functions, particularly tanh
  • Basic proficiency in calculus and logarithmic functions
  • Review integration techniques for rational functions
  • Study the properties and applications of hyperbolic functions
  • Explore the derivation and implications of the quadratic drag equation
  • Investigate common pitfalls in logarithmic calculations
Students and professionals in physics, mathematics, and engineering who are working on problems involving motion with quadratic drag, as well as those interested in advanced integration techniques.
matpo39
hi, i am trying to show that
dv/(1- (v^2/v_ter^2)) = g*dt which after integrating is
v=v_ter*tanh(g*t/v_ter) (motion with quadratic drag) can also be obtained by using natural logs.
so far i have this:
letting u = v/v_ter
i can use partial fractions to get
du/(1-u^2) = 1/2 *(1/(1+u) + 1/(1-u)) *du
then using my limits of integration as 0 to u , i get
1/2* [ln(1+u) + ln(1-u)] = g*dt
then integrating the other side i get as my final equation
1/2 *[ ln(1+v/v_ter) + ln(1-v/v_ter)] = g*t
but when i tried to plug numbers into each equation the numbers didnt match.
does anyone know what i may have done wrong?
thanks
What is [tex]\int \frac{1}{1- \frac{v^{2}}{v_{0}}} dv[/tex], look it up in an integral table, you shouldn't have to resort to partial fractions, I suspect that it will be arctanh()...
First of all, great job using partial fractions to solve the quadratic drag equation! You are on the right track.
Upon plugging in numbers, it is possible that you may have made a mistake in your integration or in plugging in the limits of integration. Double check your work and make sure that all of your calculations are correct.
Additionally, it is important to note that the natural log function is a complex equation and can sometimes give different results depending on how it is evaluated. It is possible that the slight discrepancy in your answers could be due to this.
Overall, your approach and use of partial fractions is correct. Keep working through the problem and double check your calculations to ensure accuracy. Good luck!
  • · Replies 27 ·
