How to Calculate Spring Compression and Body's Launch Height from Falling Mass?
The discussion revolves around a physics problem involving a falling mass, a spring, and the calculations related to spring compression and launch height. The problem includes a mass of 15 kg falling from a height of 135 m onto a spring with a spring constant of 1.95 x 105 N/m.
  • The original poster attempts to calculate the force exerted by the mass and its effect on the spring, but expresses uncertainty about the small displacement calculated. They also seek clarification on the relationship between kinetic and potential energy in the context of the problem.
Participants are engaging in a dialogue about the application of conservation of energy principles to the problem. Some guidance has been offered to reconsider the approach using energy conservation rather than direct force calculations.
The original poster mentions a lack of familiarity with energy conservation concepts, indicating that this may be a learning opportunity for them. There is also a note about heat loss being irrelevant in this context.
DEckrich7
A falling body has a mass of 15 kg over a height of 135 m onto a spring. The spring has a spring constant of 1.95*105N/m.
a) How far is the spring compressed?
b) At the point where the body's impact on the spring scale the greatest, what is the reading?
c) Assuming all of the elastic potential energy in the compressed spring scale is converted into kinetic energy, what is the body's initial velocity?
d) How high will the body launch?
F=ma, F=-kx, Ue= .5*k*x2, K=.5*m*v2, Weight=mg, UG=mgy
Since we're in the metric system, I'm using the gravitational constant of 9.8 m/s2. So, with F=ma, I'll do F=15kg*9.8m/s2 to give me a force of the body on the scale of 147 N. I'll substitute that value into F=-kx along with the spring constant and solve for x. 147 N/1.95*105N/m yields a displacement of about 7.54*10-4m. This seems really small however... For letter b, I'm assuming I'll multiply 15kg and 9.8m/s2 to find the body's weight in Newtons. For c) and d), I'm just stuck.
Thank you all for your time :).
Welcome to PF!
Hi DEckrich7! Welcome to PF! :wink:
So, with F=ma, I'll do F=15kg*9.8m/s2 to give me a force of the body on the scale of 147 N. I'll substitute that value into F=-kx along with the spring constant and solve for x.…
Nooo, that won't work at all :redface:
Start again, using conservation of energy
what do you get? :smile:
Thank you very much, I am so happy to join the community!
We haven't learned much about the conversation of energy in my class; a similar question to this one was my physics quiz, so we should know how to do this one however (so I should have enough knowledge to solve it!). What I do know however, is that initial Kinetic and potential energy, are equal to the final kinetic and potential energy. I also know that Etotal= K+PE+Q. Would that mean the body his bouncing off of the spring with the same velocity it is hitting it with?
Thank you very much, tiny-tim :)
Hi DEckrich7! :wink:
That's right, KE + PE = constant.
In this case, the PE is both gravitational PE (=mgh) and spring PE (= 1/2 kx2)
(btw, what's Q? :confused: if it's heat, ignore it in problems like this)
So, for a), KEinitial and KEfinal are both 0, so that should give you an equation in x …
Thank you very much for your help tiny-tim, I'll work on the problem, and yes, Q is heat loss.
