New Reply
2D Kinematics Problem (Projectile Motion)
Share Thread Thread Tools
Nov3-10, 08:42 AM   #1
Hi, I'm in a calculus base physics course in college so i thought this forum would be appropriate to post this question. The question is as follows:
"A cannonball leaves the end of the cannon with an initial velocity of 67 m/s. Assuming a level terrain, at what angle(s) to the horizontal must the cannonball be fired to hit a target 402.3 meters away?"
2. Relevant equations
X=Xo+Vo(t)+(1/2)(a)(t)^2
V=Vo+a(t)
V^2=Vo^2+(2)(a)(X2-X1)
3. The attempt at a solution
Basically i have been struggling with this problem for awhile now and I'm stuck. I wrote out my horizontal and vertical information in an attempt to maybe find the time it takes for the object to reach its target. It turns out there is not enough information to solve for any of the un-known variables in the equations I listed above. I also cannot use SOH-CAH-TOA to solve for the vertical and horizontal velocities because they don't give enough information.
If anyone can help me through the steps on how to solve this it would be great!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Nov3-10, 10:10 AM   #2
Call the angle of projection theta, [tex]\theta[/tex].
In terms of theta, write an equation relating the horizontal distance traveled with the time of flight. You will have two unknowns, theta and the time of flight.
Again in terms of theta, write an equation for vertical displacement from the start of the motion to the end (net vertical displacement should be zero since the ground is level). Again, you will have two unknown variables, the angle of projection and the time of flight.
Nov3-10, 10:46 AM   #3
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by Dcarroll View Post
V=Vo+a(t)
X is important, of course, but the last two equations are not relevant. What is relevant, that you have NOT given is the y component. What are the equations for vertical motion?
Also, you need the fact that the x component of initial velocity is V0 cos(theta) and the y component is V0 sin(theta).
New Reply
Tags
projectile motion 2d
Thread Tools
Similar Threads for: 2D Kinematics Problem (Projectile Motion)
Thread Forum Replies
Projectile motion and kinematics in 2D Introductory Physics Homework 2
Projectile Motion/Kinematics Introductory Physics Homework 1
Kinematics projectile motion problem Introductory Physics Homework 5
Kinematics - Projectile Motion Introductory Physics Homework 1
