Does This Railgun Force Calculation Look Correct?
  • Context: Graduate
  • Thread starter Thread starter MaximumTaco
    Force Railgun
The forum discussion focuses on the calculation of the force on a projectile in a railgun setup, utilizing the equation F(x) = i B(x) dx. The magnetic field |\vec{B}(x)| is derived using the formula |\vec{B}(x)| = \frac{i \mu_0}{2 \pi}(\frac{1}{x} + \frac{1}{-x+R+w}), where i is the current, \mu_0 is the permeability of free space, w is the rail separation, and R is the radius of the circular rail. The final force expression is given as |\vec{F}| = \frac{i^2 \mu_0}{\pi} log(\frac{r}{r+w}), with suggestions to adjust the integration limits for accuracy, indicating that the integral should start at R/2 and end at R/2+w to yield a more precise result.
  • Understanding of electromagnetic theory, specifically magnetostatics.
  • Familiarity with calculus, particularly integration techniques.
  • Knowledge of railgun mechanics and design principles.
  • Basic grasp of the physical constants involved, such as \mu_0 (permeability of free space).
  • Research the implications of pulsed environments on magnetic field calculations in railguns.
  • Study advanced integration techniques for electromagnetic force calculations.
  • Learn about the effects of varying rail separation on projectile force in railgun systems.
  • Examine the role of current distribution in determining magnetic fields in conductive materials.
Physicists, electrical engineers, and hobbyists interested in railgun technology and electromagnetic force calculations.
MaximumTaco
Hi all.
I've been trying to nut out an expression for the force on the projectile
( i hope you have an understanding of the basic structure of a railgun, i don't want to draw it)
Anyway, i is known, w is the rail separation, and R is the circular rail's radius.
F(x) = i B(x) dx
(the scalar magnitudes of F and B, we know what the directions are of course)
So we need to integrate across the whole length of the projectile, w
[tex] |\vec{B}(x)| = \frac{i \mu_0}{2 \pi}(\frac{1}{x} + \frac{1}{-x+R+w})[/tex]
at any point distance x along the gap
Thus,
[tex] <br /> |\vec{F}| = \frac{i^2 \mu_0}{2 \pi} \int_{w}^{0} \frac{1}{x} + \frac{1}{-x+R+w} dx<br /> [/tex]
And ultimately get...
[tex] <br /> \frac{i^2 \mu_0}{\pi} log(\frac{r}{r+w})[/tex]
Does this look right?
The first part of your setup looks reasonable. You are approximating the current-carrying wire as two infinite "line currents" at the center of the wire. Then you are cutting the result in half, assuming that the line currents are really "half a line".
This is good for manetostatic applications. For the pulsed environment of the railgun it may not be accurate, but I can't come up with a better approximation.
I have a bit of a problem with the limits in
[tex] |\vec{F}| = \frac{i^2 \mu_0}{2 \pi} \int_{w}^{0} \frac{1}{x} + \frac{1}{-x+R+w} dx[/tex]
though, it seems to me that the intergal should start at R/2 and go to R/2+w
This will change ln(r/(r+w)) to ln(r/(r+2w))
Also, if you want the force to be positive, it should be ln(1+2w/r).
  • · Replies 61 ·
  • · Replies 19 ·
