New Reply
Heat Transfer - Conduction and Radiation
Share Thread Thread Tools
Nov5-10, 01:37 AM   #1
An animal has a core body temperature of 37oC and a skin temperature of 34oC while in surrounding of an air temperature of 25oC. If the skin temperature fell, what would happen to:
(i) the rate of heat transfer via conduction through body tissue?
(ii) the rate of heat loss via radiation
2. Relevant equations
Q = h * A * [change in temp]
Qnet = e * (boltzsman) * (Tsurface4 - Tenvironment4)
3. The attempt at a solution
(i) the rate of transfer due to conduction will increase because the change in temperature has increased. e.g. (37 - 30) > (37 -34)
(ii) the rate of transfer due to radiation will decrease because the Tsurface4 has decreased.
Whilst my solution seems ok, doesn't the heat transfer need to be conserved?
ie. my textbook says the following:
" Heat must be transferred away from the outer surface at the same rate as it arrives there"
So I take this to mean, if one increases the other must increase and vice versa, If one decreases, the other must decrease.
With my solution, I have conduction increasing but radiation decreasing...
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Nov5-10, 07:20 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Solution looks good to me. And I agree with your argument about energy conservation; in fact, that's why skin temperature is maintained at an equilibrium level that remains stable unless one of the other parameters changes also.
New Reply
Thread Tools
Similar Threads for: Heat Transfer - Conduction and Radiation
Thread Forum Replies
Conduction of Heat and Radiation problem Introductory Physics Homework 1
Heat transfer via conduction. Advanced Physics Homework 1
conduction heat transfer mechanisms Introductory Physics Homework 1
Heat Transfer (Conduction) problem Introductory Physics Homework 1
Heat Transfer - Conduction Engineering, Comp Sci, & Technology Homework 0
