Calculating Power Generated by DC Generator for 6V Battery
  • Thread starter Thread starter cloud_skyblue
    Battery Generator
This discussion focuses on calculating the power generated by a DC generator to charge a 6V battery. The voltage output is determined using the formula E = N B v sin(theta), where E is the voltage, N is the number of turns, B is the flux density, and theta is the angle between the coil's vector and the magnetic field. To calculate actual power, the user needs to apply the formula P = V^2/R, where R is the resistance of the load. The goal is to use the generated power to illuminate a light bulb for a specified duration.
  • Understanding of basic electromagnetism principles
  • Familiarity with DC generator operation
  • Knowledge of electrical power formulas
  • Basic circuit analysis skills
  • Research how to calculate resistance for different light bulb types
  • Learn about the efficiency of DC generators
  • Explore methods for measuring voltage and current output from a generator
  • Investigate battery charging characteristics for 6V batteries
This discussion is beneficial for hobbyists, electrical engineers, and anyone interested in renewable energy projects involving DC generators and battery charging systems.
cloud_skyblue
Hi, I'm trying to work on this interesting little project that involves charging a 6V battery using a simple DC generator powered by a wheel spun manually. The equations for the DC generator output would be :
E = N B v sin(theta) x 10-8
if I'm correct. E being the voltage, N=number of turns, B=flux density, and theta is the angle between the coil's vector and the magnetic field.
My problem is, this only gives me the voltage. How would I get the actual power generated by the generator? All I know about the battery is that it is 6V and 5AH.
My goal is to have the battery power up a light bulb for a given duration. Any ideas?
P = V^2/R
If the generator gives the impedance you can plug the numbers.
  • · Replies 55 ·
13K
  • · Replies 38 ·
10K
