How Does Lenz's Law Explain the Movement of a Loop Near a Current-Carrying Wire?
This discussion focuses on the application of Lenz's Law to analyze the behavior of a rectangular loop near a current-carrying wire. The magnetic flux through the loop is derived using the formula B=1/2\,\mu_{{0}}ib\ln \left( {\frac {c+a}{c}} \right) {\pi }^{-1}. When the current in the wire is suddenly switched off, the loop experiences a clockwise induced current, causing it to move towards the wire due to the magnetic attraction. However, the movement is contingent on the current decreasing gradually rather than instantaneously reaching zero.
  • Understanding of Lenz's Law and its implications in electromagnetism.
  • Familiarity with magnetic flux calculations and the formula B=1/2\,\mu_{{0}}ib\ln \left( {\frac {c+a}{c}} \right) {\pi }^{-1}.
  • Knowledge of the right-hand rule for determining current direction in magnetic fields.
  • Basic principles of electromagnetic induction and forces between current-carrying conductors.
  • Study the implications of Lenz's Law in various electromagnetic scenarios.
  • Explore the derivation and applications of magnetic flux in different geometries.
  • Investigate the effects of sudden changes in current on nearby conductive loops.
  • Learn about the right-hand rule in greater detail and its applications in circuit analysis.
Students of physics, particularly those studying electromagnetism, as well as educators and anyone interested in the practical applications of Lenz's Law in circuit design and analysis.
joriarty
The diagram below shows two circuits: a very long straight wire, and a single loop rectangle of dimensions a and b. The rectangle lies in a plane through the wire and is placed a distance c from the long wire as shown. The long straight wire carries a current of I.
[PLAIN]http://img121.imageshack.us/img121/6890/screenshot20101107at259.png
a. Derive an expression for the magnetic flux Φ through the area of the rectangle. Hint: Consider small strips of area inside the rectangle of length b and width dr.
b. Using the diagram for the previous problem explain what would happen to the position of the rectangular loop if the current through the long straight wire was suddenly switched off and the rectangular loop was free to move.
For part (a) I derived [tex]B=1/2\,\mu_{{0}}ib\ln \left( {\frac {c+a}{c}} \right) {\pi }^{-1}[/tex].
But I'm not sure how to do part (b). I'm thinking I could use Lenz's Law, if I could find the current direction for the loop. Using the right hand rule I think this current would be going clockwise, same direction as the wire. A current in two wires going in the same direction will mean the loop moves towards the wire.
I agree with your part (a) answer.
For part (b), I think you are correct and I agree that the loop current is clockwise. But I have some reservations, because it says the wire current is turned off suddenly. The attraction towards the wire only holds true while the wire's current is reduced, but not yet zero. I guess "suddenly" still allows a small amount of time to take place while the current drops to zero, otherwise there would be no force on the loop.
Also, I wouldn't say that the straight wire has a clockwise current -- that does not make sense.
