Thanks for your help.Transformer Ratings: Questions & Answers
  • Thread starter Thread starter Lunat1c
    Transformer
The transformer rating of 2000kVA refers to both the primary (input) and secondary (output) sides, indicating the maximum loading capacity. In a three-phase 2000kVA transformer configured as delta-star, the apparent power per phase is approximately 667kVA, which is one-third of the total rating. This understanding is crucial for accurate calculations and applications in electrical systems.
  • Understanding of transformer ratings and specifications
  • Knowledge of three-phase power systems
  • Familiarity with delta and wye (star) configurations
  • Basic electrical engineering principles, including power calculations
  • Research "Transformer efficiency and losses" to understand real-world applications
  • Study "Three-phase power calculations" for deeper insights into phase power distribution
  • Learn about "Delta vs. Wye transformer configurations" for practical applications
  • Explore "Transformer design and ratings" for advanced engineering concepts
Electrical engineers, students studying power systems, and professionals involved in transformer design and application will benefit from this discussion.
Lunat1c
Hi,
I have a couple questions regarding transformers:
1. When you're told that a particular transformer is rated at 2000kVA, is that referring to the output or to the input rating of the TX? Or is it correct to say that the apparent power on both windings will be equal to that?
I view the 2000kVA as the maximum loading of the transformer (even though it can be overloaded a bit with the correct setup) however with this in mind I'm having doubts whether I can use S=VI on any of the two windings.
2. If you have a 2000kVA three-phase 30000/6000V transformer connected as delta-star, then is the apparent power per phase equal to 2000kVA or is that the total?
Seeing how this post is a couple of months old and no one has replied, I'll assume that the OP has either given up, or found the answer to his questions.
In the interest of answering these questions for those interested, I have decided to post my answers even though this is a homework forum.
1. The kVA rating of a transformer refers to both the primary (input) and secondary (output) side of the transformer. Remember, power in equals power out. Of course, there is a bit of loss due to heat, but for the sake of calculations, a "perfect" transformer is considered (that is, one that loses no power to heat).
2. The power per phase of a three phase transformer is one-third the overall power rating of the transformer (whether delta- or wye-connected). So, there would be approximately 667 kVA per phase.
For more information, see: http://ecmweb.com/mag/electric_understanding_basics_wye/
  • · Replies 33 ·
10K
