What is the Angle of Repose for Granular Materials?
The angle of repose for granular materials is defined as the steepest angle at which a slope of granular material remains stable without sliding. In the discussion, Rhys outlines three methods to calculate this angle, with a simple method involving a funnel releasing sand onto a card to form a cone. The angle can be calculated using trigonometry based on the cone's radius. Rhys plans to test different particle sizes of sand and salt to gather empirical data for his coursework.
  • Understanding of trigonometry for angle calculations
  • Familiarity with empirical testing methods
  • Knowledge of granular material properties
  • Experience with experimental design and setup
  • Research empirical equations related to the angle of repose
  • Explore methods for measuring particle size distribution
  • Investigate the effects of moisture content on angle of repose
  • Learn about advanced techniques for analyzing granular flow behavior
Students in engineering or materials science, researchers studying granular materials, and professionals involved in civil engineering or geotechnical analysis will benefit from this discussion.
Rhysics
For my coursework, i am investigating the angle of repose of granular materials. However, for my coursework to be. . . successful i need to prove or disprove a theory or an empirical equation which i can test. So far from my research i have not found a simple... or appropriate complexity theory or equation. So... if you know/can think of any theories or equations i can test on this area please let me know.
Background:
Angle or repose is the steepest angle of descent or dip of the slope relative to the horizontal plane when material on the slope face is on the verge of sliding.
I have 3 methods to calculate the angle of repose, each have a different setup.
An example of one - the simplest one. Is to have a funnel full of sand a fixed height above a piece of card. The sand is then released from the funnel (via a nozzle) onto the card. This will form a cone of sand, and from this cone the angle of repose can be calculated, using trig and knowing the radius of the cone. The sand is of a certain particle size, and i have 3 differing particle size sand samples to use. I will also use salt, as it is easy to get differing particle size samples to use.
Thanks in Advance
Rhys
unfortunately, i have already been on all those sites you suggested. But thanks for the effort
  • · Replies 23 ·
  • · Replies 23 ·
