Solve for K for Continuity of f(2) at @=0
  • Thread starter Thread starter Hygelac
    Continuity
The problem involves determining a value of K to ensure the continuity of a piecewise function at a specific point, where the function is defined differently for values approaching zero and at zero itself.
  • Exploratory, Assumption checking
  • Participants discuss using limits to find the value of K, with one suggesting L'Hôpital's rule as a method to evaluate the limit as the variable approaches zero. There is also a clarification regarding the function notation.
The discussion is ongoing, with participants exploring different interpretations of the problem and the correct application of limits. Some guidance has been offered regarding the use of limits, but there is no explicit consensus on the approach yet.
There is a noted confusion regarding the function notation and the specific point of continuity being addressed. Participants are also considering the implications of the function's definition at zero.
Hygelac
Hi, I have just one more problem :) here it is:
(because I don't know how to do theta, "@" will equal theta)
Find a value of K so that f(2) is continuous at @=0
( != means "not equal")
Code:
f(@) = ( (2sin@)/@ , @ !=0 )
       ( 5k , @=0 )
f(@) is a piecewise function
I don't know how to get started on this problem, any help would be much appreciated :)
The simplest way would be to set 5k = lim(@->0)[2sin(@)/@]
Using l'hopital's rule, lim(@->0)[2sin(@)/@] = lim(@->0)[2cos(@)/1]
I think you can do the rest :)
Whops, it shoudl be f(@) not f(2)
So,
5k = (2sin(@))/@
k = [(2sin(@))/@]/5
Would that work, or did I totally miss your point?
So,
5k = (2sin(@))/@
k = [(2sin(@))/@]/5
I think you may have because that doesn't work. that function is not defined at @ = 0 so you have to use limits. k = 1/5 * limit[@->0](2sin(@)/@)
  • · Replies 20 ·
