Understanding Rotations on a Polar Grid | Geometry Explained
  • Context: High School
  • Thread starter Thread starter mactony
    Geometry
The discussion focuses on rotating an image 105 degrees on a polar grid, clarifying the angular representation of the grid. The top half of the polar grid spans from 0 degrees to 180 degrees, while the bottom half can be represented as either 180 degrees to 360 degrees or 0 degrees to -180 degrees, depending on the reference direction. The key takeaway is that for a full rotation, the polar angle should cover 0 to 360 degrees, encompassing both halves of the grid. Accurate mapping of points requires understanding this angular representation.
  • Understanding of polar coordinates and grids
  • Knowledge of angular measurement in degrees
  • Familiarity with image rotation concepts
  • Basic geometry principles related to circular shapes
  • Research the mathematical principles of polar coordinates
  • Learn about image transformation techniques in computer graphics
  • Explore the concept of angular displacement and its applications
  • Study the differences between counterclockwise and clockwise rotations
Mathematicians, computer graphics developers, and anyone interested in understanding image transformations on polar grids.
mactony
Hi,
I'm rotating an image 105 degrees on a polar grid. I know the top half of the polar grid is 0 degrees to 180 degrees, but what about the bottom half? Is it the same as the top 0 degrees to 180 degrees, or does it go all the way to 360 degrees.
Oops, forgot to clarify in case my question is too vague. Ok, let's say I have an image on the top half of the grid which is 0 degrees to 180 degrees. I have to rotate it , and the new figure would end up on the bottom half the grid. Polar grids are shaped like a circle. I have to map the points of the original image and the new image. Would the bottom image points be 180 degrees to 360 degrees or 0 degrees to 180 degrees.
Mathematics news on Phys.org
Generally, you would have the polar angle covering 0 to 360 degrees for a full rotation (i.e. it covers both top and bottom) but there is nothing wrong with 0 to 180 (counterclockwise) on the top and 0 to -180 (clockwise) on the bottom starting from the same reference direction (x-axis).
So if I was mapping the points, would it be -75 degrees for example, or would it be over 180 degrees, I am just rotating an image.
