Why Do My Physics Calculations on Force and Acceleration Keep Going Wrong?
  • Thread starter Thread starter buffgilville
    Acceleration Force
The discussion focuses on solving physics problems related to force and acceleration on inclined planes. For a mass of 1.3 kilograms pushed with a horizontal force of 17.5 Newtons at a 12.5-degree angle, the correct acceleration is calculated as 11 m/s², factoring in both the horizontal force component and gravitational force. In the second problem, a mass of 1.9 kilograms with a horizontal force of 20 Newtons at a 27-degree angle results in a distance of 198.13 meters traveled in 6.5 seconds, using the formula d = 1/2at². The key takeaway is the importance of correctly applying the components of forces and using appropriate formulas for calculations.
  • Understanding of Newton's Second Law (F = ma)
  • Knowledge of trigonometric functions (sine and cosine)
  • Familiarity with kinematic equations (d = 1/2at²)
  • Basic concepts of inclined planes in physics
  • Study the application of trigonometric functions in physics problems
  • Learn about inclined plane dynamics and forces
  • Practice solving problems using kinematic equations
  • Explore advanced topics in classical mechanics, such as friction and energy conservation
Students studying physics, educators teaching mechanics, and anyone interested in mastering calculations involving force and acceleration on inclined planes.
buffgilville
1) A mass 1.3 kilograms is pushed with a horizontal force 17.5 Newtons of a smooth inclined plane which bears an angle 12.5 to the horizontal. Find the acceleration of the mass (g = 9.81 m/s).
I got 2.12, but it was wrong, and I don't know why.
2) A mass 1.9 kilograms is pushed with a horizontal force 20 Newtons of a smooth inclined plane which bears an angle 27 to the horizontal. Find the distance the block moves in 6.5 seconds (g= 9.81 m/s2).
I got 198.13, but it was wrong, and I don't know why.
This is a matter (also for the second question) of using the right components of given forces. The given force is HORIZONTAL so you need the component of this force in the direction that the object moves: 12.5 degrees upwards.
F = ma so that a=F/m and F = 17.5*cos(12.5)
I get 13.1 m/s² for this one
Then there is gravity F =m*g pointing down vertically. The component of this force along the inclination is -m*g*sin(12.5). And minus because it points DOWN the y-axis...so the acceleration here is -2.1 m/s²
So I get : 13.1 - 2.1 = 11 m/s² as an anwser...
marlon
same thing for the second question : draw a sketch and call the inclination the x-axis...
In both of these problems, it is important to understand the relationship between force, mass, and acceleration. The formula for calculating force is F=ma, where F is force, m is mass, and a is acceleration. In the first problem, we are given the mass, force, and angle of the inclined plane, and we are asked to find the acceleration. The correct formula to use in this situation is F=mg sinθ, where θ is the angle of the inclined plane. Plugging in the given values, we get F= (1.3 kg)(9.81 m/s^2) sin(12.5) = 2.12 N. Therefore, the acceleration is 2.12 m/s^2.
In the second problem, we are given the mass, force, and time, and we are asked to find the distance. To solve this, we can use the equation d= 1/2at^2, where d is distance, a is acceleration, and t is time. Plugging in the given values, we get d= 1/2(1.9 kg)(9.81 m/s^2)(6.5 s)^2 = 198.13 m. Therefore, the distance the block moves in 6.5 seconds is 198.13 meters.
It is important to carefully read and understand the given information in a problem and use the correct formula to solve it. If you are unsure why your answer is incorrect, double check your calculations and make sure you are using the correct formula. It can also be helpful to show your work and check your answer with someone else to catch any mistakes. Keep practicing and you will become more confident in solving problems involving force and acceleration.
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 24 ·
