How to use matrices to solve systems of ODEs?
  • Context: Graduate
  • Thread starter Thread starter medstudent
    Matrices Odes Systems
The discussion revolves around the use of matrices to solve systems of ordinary differential equations (ODEs), specifically focusing on first-order coupled equations. Participants explore various methods and steps involved in this process, including matrix representation, diagonalization, and the role of eigenvalues and eigenvectors.
  • One participant presents a system of three coupled first-order ODEs and seeks guidance on using matrices for solutions.
  • Another participant confirms the importance of diagonal matrices and questions the functions that satisfy the differential equations.
  • Several participants outline steps for solving the system, including writing the system in matrix form, diagonalizing the coefficient matrix, and finding eigenvalues and eigenvectors.
  • There is mention of expressing the solution as a linear combination of eigenvectors and using initial conditions to solve for constants.
  • One participant emphasizes the need to rewrite higher-order ODEs as systems of first-order ODEs before applying matrix methods.
Participants generally agree on the steps involved in using matrices to solve systems of ODEs, but there are variations in the details of the methods proposed. No consensus is reached on the specific functions satisfying the differential equations or the best approach to diagonalization.
Some limitations are noted, such as the requirement to convert higher-order ODEs into first-order systems before applying matrix techniques. Additionally, the discussion does not resolve the specifics of the functions that satisfy the equations or the nuances of diagonalization.
medstudent
I'm dealing with systems of 3 differential equations that are all coupled to each other. Fortunately, all the ODEs are first order.
Can somebody give me a primer of how to use matrices to solve these problems?
here's an example:
Say we have a system of 3 ODEs all coupled to each other:
Mx, My, Mz
dMx/dt = A*Mx + B*My + C*Mz
dMy/dt = D*Mx + E*My + F*Mz
dMz/dt = G*Mx + H*My + J*Mz
So the matrix would be:
dM/dt = [A B C
D E F
G H J] M + [K L M]
So what do I do now? Diagonalize the matrix and then find eigenvectors? Whats the step by step?
That's right.
Now, suppose you've got a diagonal matrix.
What are the functions satisfying those differential equations?
To solve systems of ODEs using matrices, we can follow these steps:
1. Write the system of ODEs in matrix form: As shown in the given example, we can write the system of ODEs as dM/dt = AM + B, where M is a column vector of the variables (Mx, My, Mz), A is the coefficient matrix, and B is a column vector of the constants.
2. Diagonalize the coefficient matrix: To diagonalize the matrix, we need to find its eigenvalues and eigenvectors. This can be done by solving the characteristic equation det(A-λI) = 0, where I is the identity matrix and λ is the eigenvalue. Once we have the eigenvalues, we can find the corresponding eigenvectors by solving the equation (A-λI)x = 0.
3. Write the solution as a linear combination of the eigenvectors: Once we have the eigenvalues and eigenvectors, we can write the solution as M = Ce^(λt)v, where C is a constant and v is the eigenvector.
4. Solve for the constants: To solve for the constants, we can use the initial conditions given in the problem. Substitute the initial values of the variables into the solution and solve for the constants.
5. Substitute the values back into the solution: Once we have the values of the constants, we can substitute them back into the solution to get the final solution of the system of ODEs.
Overall, the steps involved in using matrices to solve systems of ODEs are similar to solving a single ODE using the method of undetermined coefficients. However, instead of using a single exponential function, we use a linear combination of exponential functions based on the eigenvalues and eigenvectors of the coefficient matrix.
To solve a system of ODEs using matrices, we first need to rewrite the system in matrix form. This can be done by grouping the dependent variables (Mx, My, Mz) and their derivatives (dMx/dt, dMy/dt, dMz/dt) into a matrix and the coefficients (A, B, C, D, E, F, G, H, J) into a coefficient matrix. This gives us the following matrix equation:
dM/dt = AM + BM
where A is the coefficient matrix and M is the matrix of dependent variables.
Next, we need to find the eigenvalues and eigenvectors of the coefficient matrix A. This can be done by solving the characteristic equation det(A-λI) = 0, where λ is the eigenvalue and I is the identity matrix. The eigenvalues and eigenvectors will help us to diagonalize the coefficient matrix and simplify the system of ODEs.
Once we have the eigenvalues and eigenvectors, we can diagonalize the coefficient matrix by finding the matrix P that satisfies AP = PD, where D is a diagonal matrix with the eigenvalues of A on the diagonal. This gives us:
dM/dt = P^-1DPM + P^-1BMP
We can then solve for M by using the substitution M = P^-1N, where N is a new matrix of dependent variables. This gives us the following equation:
dN/dt = DN + BP^-1N
This equation can now be solved using standard techniques for solving first-order ODEs. Once we have the solution for N, we can substitute it back into M = P^-1N to get the solution for the original matrix of dependent variables.
In summary, to solve a system of ODEs using matrices, the steps are:
1. Rewrite the system in matrix form.
2. Find the eigenvalues and eigenvectors of the coefficient matrix.
3. Diagonalize the coefficient matrix.
4. Solve for the new matrix of dependent variables.
5. Substitute the solution back into the original matrix of dependent variables.
It is important to note that this method only works for systems of first-order ODEs. If the system contains higher-order ODEs, they must be rewritten as a system of first-order ODEs before using this method.
  • · Replies 28 ·
