Solve Heating Water Problem: 100-W Electric Heater
  • Thread starter Thread starter SpatialVacancy
    Heating Water
The discussion revolves around a problem involving a 100-W electric heater and its ability to heat a quart of water from room temperature (20°C) to boiling point. Participants are exploring the relationship between power, heat transfer, and temperature change in the context of specific heat capacity.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the specific heat capacity of water and its relevance to the problem. There are attempts to relate the power of the heater to the heat required to raise the water's temperature. Questions arise regarding the definition of a quart and the implications of specific heat in the calculations.
Some participants have provided insights into the equations related to specific heat and power, suggesting that understanding these relationships is crucial for solving the problem. There is an ongoing exploration of the definitions and units involved, with no explicit consensus reached yet.
There is a mention of potential confusion regarding the unit of measurement for the volume of water and the specific heat capacity. Additionally, some participants express uncertainty about the terminology used in the equations, particularly regarding the representation of heat.
SpatialVacancy
Hello all,
I do not know how to solve this proble and was wondering if you could offer some guidance.
Question:
How long after it is turned on will a 100-W electric
heater take to bring a quart of water to a boil from room
temperature 20 deg C?
Here's what I know:
[tex]T_i=20[/tex]
[tex]T_f=100[/tex]
[tex]\Delta T=80[/tex]
[tex]100W = \frac{100J}{1s}[/tex]
Thanks!
I'm don't know what a quart is. However, I do know the specific heat capacity of water which is 4180J/kgK. This means that for every kilogram of water, 4180 joules of energy is needed to raise the temperature by 1 Kelvin or 1 degree celsius.
The key to this problem is knowing how much the temperature of water increases when a certain amount of heat is added. This is basically the definition of the specific heat:
[tex]c = \frac{1}{V}\frac{\Delta Q}{\Delta T} \Rightarrow \Delta Q = cV\Delta T[/tex]
where [tex]c[/tex] is the specific heat and [tex]V[/tex] is the volume of the substance, in this case water. This equation is what you need to solve the problem. However, you are not told anything about the added heat. You are given information about the heater power. Assuming that all of the power goes into heating the water we can write:
[tex]P = \frac{\Delta Q}{\Delta t}=cV\frac{\Delta T}{\Delta t}[/tex]
where [tex]\Delta t[/tex] is the time it takes to add the amount of heat [tex]\Delta Q[/tex]. Just solve for [tex]\Delta t[/tex].
I think c has units of (J/m^3*K) for you. It is not the usual definition of the specific heat which is always written in term of masses (J/KgK). Anyway you have solved very good the problem indeed, in my opinion.
If you want and advice never write again [tex]\Delta Q[/tex]. The "increment" or "variation" of heat has none physical meaning. It has no sense. The heat does not vary. A body does not have any heat itself. So that no variation is possible. Instead of it, write simply [tex]Q[/tex] or [tex]\delta Q[/tex] (inexact differential) when you talk about heat.
It was only a some clearings, in my opinion your solution sounds very good.
23K
