Powder pattern calculation from single crystal data
The discussion centers on the theoretical basis for calculating X-ray powder diffraction patterns from single crystal data. Participants explore the relationship between the two types of diffraction data, the methods for conversion, and the differences that may arise between theoretical and experimental powder patterns.
  • One participant inquires about the theoretical foundation for calculating powder patterns from single crystal data and questions whether the obtained patterns match experimental results.
  • Another participant suggests that powder data can be viewed as a projection of single crystal data onto a 1D axis, where each (hkl) reflection corresponds to a specific intensity at a point on the axis.
  • Several participants express a need for resources or textbooks that specifically address the mathematical methods for converting single crystal diffraction data to powder patterns.
  • A participant mentions that the conversion process involves using a .hkl file with intensities and specifies that the geometry of the XRD experiment affects the resulting powder pattern.
  • There is a discussion about the differences between powder diffraction and single crystal diffraction, particularly regarding the integration of peaks and the profile of the data.
  • One participant asks how to derive Miller indices and cell parameters from a powder XRD pattern, indicating a need for formulas related to these calculations.
  • Another participant suggests starting with a cubic system to understand the relationship between Miller indices and d-spacing.
  • There are requests for assistance with processing single crystal X-ray data and extracting relevant information from XRD patterns.
Participants express various viewpoints and questions, indicating that there is no consensus on the theoretical methods or the specifics of converting single crystal data to powder patterns. Multiple competing views and unresolved inquiries remain throughout the discussion.
Some participants note the need for specific theoretical methods that are not covered in general crystallography textbooks, highlighting potential gaps in available resources. The discussion also reflects uncertainty regarding the impact of experimental parameters on the conversion process.
Mabied738
Hi
Kindly, I want to know what the theoretical base of X-ray powder diffraction pattern calculation from single crystal data? and is the obtained pattern same as experimental powder pattern and if not same what the cause of difference? Thanks
Powder data are simply a projection of all single crystal data onto 1D x-axis, i.e. for each (hkl) you take the absolute Q(hkl) and put the respective intensity on the 1D axis at the point x=Q.
Thanks a lot for your answer, can you suggest textbook or paper to read about the theory and mathematical method which describe how the software convert single crystal diffraction data to powder pattern, i.e. 2Theta versus Intensity plot.
Best Regards
Thanks
Best Regards
Well there are so many books on crystallography. Probably one of the best is by Vainshtein:
http://books.google.ch/books?id=xjI...of Crystals: Modern Crystallography,&f=false"
There is a lot of software for this. You can Google "powdercell", or www.oxfordcryosystems.com for a free copy of Crystallographica, or
"fullprof suite" or "gsas".
Thanks for sending these nice books and software, but there is specific theoretical method deal with converting single crystal data to powder pattern plot, and I didn't found it in the general crystallography textbooks, as by Vainshtein, so do you know where I can found it and what is the keywords for it?
Thanks and sorry for confusion again
This type of plot is possible in 'Winplotr' (from FullProf). Actually in general the powder pattern will depend on the geometry of XRD experiment. In short, you should use your .hkl-file with intensities and ask Fullprof to calculate the diffracton _powder_ pattern for your powder resolution parameters that are also specified in the input file in Le Bail (powder matching) mode. To make a really true conversion one needs a collection of reflections within Ewald sphere (symmetric in 4pi).
A big difference in powder (PD) and SC (SCD) diffraction experiment is that in the PD you have a profile I(2\theta), whereas in SCD you have already integrated peaks.
The conversion of just integrated intensities is extremely straightforward. For each reflection you calculate \theta and add the intensity to I(2\theta). You should allow some tolerance in 2\theta, because you are dealing with experimental data having some errorbars. There is also correction for Lorenz factor (LF). If your original SCD data were already corrected for LF, then you multiply I(2\theta) by 1/[sin(\theta)*sin(2\theta)]. We assume some standard Bragg-Brentano PD. This way you will get the integrated intensities, but not the profile, which is dependent on the resolution parameters.
can anyone you tell me how to get the miller indices and cell parameters from powder XRD pattern
thank you can you suggest any formula for calculating the cell parameters with 'd' and 2theata
hai
can you suggest the formula for finding the miller indices from powder xrd pattern with d and 2 theta values.
Best regards
Can you figure it out? Start with a cubic system. How are the miller indices for a family of planes in a cubic lattice related to the d-spacing for those planes?
Also, next time, start a new thread if you have a question that is different from the one being discussed in the existing thread.
can you help me in solve collected data from xrd pattern by using manual search?
Single Crystal X-ray Crtstallography Data Processing
Can anyone help me in processing the single crystal x-ray data. I have a full data including all frames, p4p files etc. I am unable to process it. Plz help
