The Asteroid (implicit differentiation)
The discussion revolves around calculating the length of the graph defined by the equation x^(2/3) + y^(2/3) = a^(2/3), which describes an astroid shape. Participants are exploring methods of implicit differentiation and integration to find the length of the curve.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss implicit differentiation of the given equation and the resulting expression for dy/dx. There is uncertainty about how to express y in terms of x to facilitate integration for the length of the curve. Some participants suggest simplifying the expression for y' and combining terms to aid in the integration process.
Some participants have made progress in deriving expressions for the length of the curve and have attempted integration. However, there remains skepticism about certain interpretations and the implications of negative values in the context of length. Multiple interpretations of the problem are being explored, and further guidance is sought by participants.
Participants note the complexity of the problem and the potential for confusion regarding the terminology used (e.g., astroid vs. asteroid). There are also references to external resources for formulas related to the astroid's perimeter and arc length, indicating a broader context of inquiry.
TicTacToe
Calculate the length of the graph/equation: x^(2/3) + y^(2/3) = a^(2/3)
The graph is formed as an s.c. asteroid, almost like a diamond. It seems to be some sort of modified unit circle.
The length of the graph between x1 and x2 can be described as L=∫ √(1+(y´(x))2) dx
Might as well throw in the Pythagorian theorem: a2 + b2 = c2
The problem can reformed this way.
x^(2/3) + y^(2/3) - a^(2/3) = 0
Implicit differentiate the LHS with respect to x (dy/dx)=
(2x^(-1/3))/3 + (2y^(-1/3))/3 * y´ = 0 (I thought of a as a constant)
y´ = - ((2x^(-1/3))/3) / ((2y^(-1/3))/3) which leads to
y´= - y^(1/3) / x^(1/3)
Now, I'm not quite sure from here and onwards.
y = (-x^(2/3) + a^(2/3))^(3/2) <--- is this correct? if so then the length of the graph could be described as
L = ∫ √(1+(-((-x^(2/3)+a^(2/3))^(3/2))^(1/3) / x^(1/3)))2
but I can't really figure this out. I mean, I still have 2 variables and it's already messy as it is. The uncertainty lies in what y should be written as. So my direct question is, could anybody solve out y from this equation and make it possible to integrate the L-equation? Thanks in advance.
It would be much more readable if you use the X2 button or simple Tex. You are on the right track you have
[tex]y' = -\frac{y^{\frac 1 3}}{x^{\frac 1 3}}[/tex]
so
[tex]y'^2 = \frac{y^{\frac 2 3}}{x^{\frac 2 3}} = <br /> \frac{a^{\frac 2 3}-x^{\frac 2 3}}<br /> {x^{\frac 2 3}}[/tex]
Now simplify 1 + y'2 by combining the two terms and you might be surprised.
Thanks LCKurtz!
Now I get the formula:
√ (a^(2/3)/x^(2/3)) dx = The length of the curve between two x-values
I guess I should integrate this next. I'll do it tomorrow and if I encounter any problems I'll ask for further guidance.
Can't really get the hang of those TEX stuff
Alright, I might have the answer to this now but I'm not quite sure. I have integrated the expression:
L = ∫ √ (a(2/3)/x(2/3)) dx =
= ∫ a(1/3)/x(1/3) dx
to
[ ∛a * (3/2) * x(2/3) ]
Known by the graph on my analog paper a is represented as the max value of x and y, both positive and negative. In the quadrangular diamond (the asteroid) a is represented as the max value of the four directions to further explain. So therefore I set x1 to -a and x2 as 0 and calculated the equation given above. I received the answer
L = -(3/2)*a
So I assumed length of the whole diamond is 4*(3/2)*a since length in this case can't be described as negative (?) and the diamond is a quadrangular where each curve is separated by the x and y angles and the curves are identical.
Does this seem to make sense? That the length of each curve is the 3/2 times longer than the max x and y value (which are the same value as a). I must admit, I am a bit skeptical to the "length can't be described as negative"-part. All help and input is greatly appreciated and everyone that helps other people in here are true heroes.
It's called ASTROID, not ASTEROID.
Aight, thanks but do you have any else that might help me with the problem?
Yes, Google astroid. There is a formula for the perimeter of this curve.
Could someone give me a hint how the formula
s(θ) = (8*(a-b)*b*(sin (aθ/4b))^2)/a
is derived. s is the arc length of the astroid's curve.
where θ is the angle of the circle with (a-b) radius.
Thanks in advance!
the formula can be find at http://mathworld.wolfram.com/Hypocycloid.html
Well, I'll try with a more simple question then, I guess. All hypocycloid can be described as a smaller circle rotating inside a larger, with a point P on the rim of the circle creating the curve. Why is then the smaller circle radius (b) * the angle in the small circle (ϑ) the same as the big circle's radius minus the small circle's radius (a-b) * the angle of the big circle (Φ)?
Simply, why is (a-b)Φ=bϑ ?
I can't seem to find any logical explanations. Do they develop the same arc length?
I really wish someone could help me with this one.
Thanks in advance.
  • · Replies 24 ·
  • · Replies 25 ·
  • · Replies 26 ·
