Calculating Maximum Volume of Sand in a Circular Area
The maximum volume of sand that can be stored in a circular area with radius R is calculated using the formula V = (1/3) * μs² * π * R² * m, where μs is the static coefficient of friction and m is the mass of the sand. The relationship between the weight of the sand and the maximum frictional force is established through Ff = μs * mg. The analysis confirms that the height of the cone of sand is directly influenced by the static friction, ensuring no spillage occurs.
  • Understanding of Newton's second law of motion
  • Knowledge of static friction and its coefficient (μs)
  • Familiarity with the geometry of cones and volume calculations
  • Basic principles of forces acting on objects in motion
  • Research the implications of static friction in material stacking scenarios
  • Explore advanced applications of Newton's laws in fluid dynamics
  • Learn about the properties of different materials affecting friction coefficients
  • Investigate the effects of varying cone dimensions on stability and volume
Engineers, physicists, construction workers, and anyone involved in material handling or storage optimization will benefit from this discussion.
winlinux
1)A hot-air balloon of mass M is descending vertically with downward acceleration of magnitude a. How much mass (ballast) must be thrown out to give the balloon an upward acceleration of magnitude a? Assume that the upward force from the air (the lift) does not change because of the decrease in mass.
3)fig3
A worker wishes to pile a cone of sand onto a circular area in his yard. The radius of the circle is R, and no sand is to spill onto the surrounding area. If s is the static coefficient of friction between each layer of sand beneath it, show that the greatest volume of sand that can be stored in this manner is . (fig3)
Newton's second law
Hi
The figures didn't seem to work for your second question, but here's my attempt at an answer for the first.
First, choose downwards to be positive. Call the upwards force due to the hot air [itex]F_{up}[/itex], and the original mass of the balloon [itex]m_i[/itex]. Therefore
[tex]m_1 g - F_{up} = m_1 a[/tex]
[tex]m_1 = \frac{F_{up}}{g-a}[/tex].
([itex]g[/itex] is gravitational acceleration, therefore [itex]m_1 g[/itex] is the weight.)
Call the new mass after the ballast has thrown out [itex]m_2[/itex]. The new acceleration is [itex]-a[/itex].
[tex] m_2 g - F_{up} = - m_2 a[/tex]
[tex] m_2 = \frac{F_{up}}{g+a}[/tex].
The difference in the mass is [itex]m_1 - m_2[/itex], which is
[tex] m_1-m_2 = F_{up}\left( \frac{1}{g-a}-\frac{1}{g+a}\right)[/tex]
[tex] m_1-m_2 = F_{up} \frac{2a}{g^2-a^2}[/tex]
To calculate the maximum volume of sand that can be stored in a circular area with a radius of R, we first need to determine the height of the cone of sand that can be piled without spilling onto the surrounding area.
Using the given information, we know that the worker must overcome the static friction between each layer of sand in order to pile the cone. This means that the maximum height of the cone can be achieved when the weight of the sand equals the maximum frictional force that the worker can exert.
We can express this relationship as:
Ff = μs * mg
where Ff is the maximum frictional force, μs is the static coefficient of friction, m is the mass of the sand, and g is the acceleration due to gravity.
Since the worker wishes to pile the sand without it spilling, the weight of the sand must be equal to the maximum frictional force, which we can express as:
mg = μs * mg
Simplifying, we get:
m = μs * m
This means that the mass of the sand must be equal to the product of the static coefficient of friction and the mass of the sand.
Now, we can use the formula for the volume of a cone to calculate the maximum volume of sand that can be stored in the circular area:
V = 1/3 * π * R^2 * h
where V is the volume, π is the constant pi, R is the radius, and h is the height of the cone.
Plugging in the value for m from earlier, we get:
V = 1/3 * π * R^2 * (μs * m)
V = μs * (1/3 * π * R^2 * m)
Since we know that the mass of the sand must be equal to μs * m, we can substitute this into the equation and get:
V = μs * (1/3 * π * R^2 * μs * m)
Simplifying further, we get:
V = 1/3 * μs^2 * π * R^2 * m
Therefore, the greatest volume of sand that can be stored in a circular area with a radius of R is given by:
This formula can be used to calculate the maximum volume of sand that can be stored
10K
12K
