Calculating Recursive Derivatives at Point x=0
  • Thread starter Thread starter Monsu
    Derivatives
The discussion revolves around calculating the recursive derivatives of a function at the point x=0, specifically focusing on the expression f(f(f(x))) given certain initial conditions for the function and its derivative.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore the implications of the initial conditions f(0) = 0 and f'(0) = 1, questioning the relevance of derivatives in the context of recursive function evaluation.
The conversation has evolved to clarify the original question about calculating the derivative of f(f(f(0))). Some participants have provided insights into the differentiation process, leading to a potential simplification, although no consensus has been reached on the final outcome.
There appears to be some confusion regarding the initial problem statement and the role of derivatives in the calculation, with participants questioning the setup and assumptions involved.
Monsu
hi, could smne pls give me an idea of how to deal with this problem?
Suppose that f(0) = 0 and that f'(0) =1 , calculate f(f(f(x))) at point x=0
thanks a lot, any hint at all would b helpful, as i completely clueless.
if f(0) = 0 then f(f(0)) = f(0) = 0.. it's recursive. I am not sure why you would need f'(x) to solve nothing to do with derivatives. Are you sure you typed the question correctly?
here it is again:
f(0) = 0 and f'(0) = 1 calculate the derivative of f(f(f(x))) at point x=0
that's the exact question.
thanks for the help on the second question
Oh I see calculate the DERIVATIVE of f(f(f(0)))
First let's set g(x) = f(f(x))
g'(x) is therefore f'(f(x))*f'(x)
Derivative f(g(x)) after substitution is f'(g(x))*g'(x)
= f'(f(f(0)))*f'(f(0))*f'(0)
What a mouthful. If I were to venture a wild crazy guess I'd say that simplifies to 1.
oh great! i just worked it out, it did come to 1. thanks a lot.
can u give a further hint on the other question, I'm still a bit confused there.
thanks again, marvellous!
  • · Replies 29 ·
  • · Replies 24 ·
  • · Replies 42 ·
