Determine a subset for the function of X -> P(X)
  • Thread starter Thread starter hocuspocus102
    Function
The discussion revolves around a function defined from a non-empty set X to its power set, specifically examining the subset Yf, which consists of elements in X that are not included in their corresponding f(x) values. Participants are tasked with determining Yf based on the function's definition.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants explore the implications of the function f and its relationship to the subset Yf, questioning whether specific elements belong to Yf based on their definitions. There is a focus on understanding the notation and the logical structure of the problem.
The discussion is active, with participants engaging in back-and-forth questioning to clarify their understanding of Yf and its relationship to the function f. Some participants suggest that Yf includes all elements of X except the one being evaluated, while others seek to confirm their interpretations through examples.
Participants are working under the assumption that the function f takes an element n from set X and returns the set of all elements in X excluding n. There is some confusion regarding the definitions and implications of Yf, leading to a need for clarification on the relationship between elements and their corresponding f values.
hocuspocus102
Suppose X is a non-empty set and f:X->power set of X (ie P(X)) is defined f(x) = X/x. Consider the subset Yf = {x in X such that x not in f(x)} of X. Determine Yf for the particular f we have just described.
Any suggestions would be helpful because I really don't know where to start on this problem...
This really isn't a profound question. It looks like it's just testing if you can read the notation. Pick X={1,2,3}. What's f(1)?
f(1) in that case would be {2,3} right? but how does that translate to Yf?
Right. Is 1 in Y_f?
no, so is Yf just X/x ?
Read the definition of Y_f again. Aloud. I don't want to know what Y_f is yet, I just want to know if 1 is in it. No is the wrong answer. Why?
no 1 isn't in it because it's x in X such that x not in f(x) and 1 is not in f(1)
If 1 is not in f(1), doesn't that mean 1 IS in Y_f?
I get that for f(1), 2 is in Y_f and 3 is in Y_f but 1 is not.
for f(2), 1 is in Y_f and 3 is in Y_f but 2 is not.
so for f(n) on a set of size t Y_f will have all numbers in the set 1 through t not including n in it. is that how you'd say that or is there a more explicit formula?
Ach. I think you are getting this wrong. 1 ISN'T in f(1). Doesn't that tell you 1 IS in Y_f? Or did you state the question wrong?
I don't know I thought f just took n to a set with all elements of X not including n because Y_f is x not in f(x)
That's really confusing. Let's go back. If X={1,2,3} is 1 in Y_f? I don't think we really ever got that one right.
no it's not
hocuspocus102 said:
no it's not
Yes, it is. Yf = {x in X such that x not in f(x)}. 1 is in X but it's NOT in f(1)={2,3}. So 1 IS in Y_f.
ohhhh. ok so Y_f is whatever value you plug in for x?
Hmm. What Y_f is actually doesn't depend on what x is. x is what's called a dummy variable. Work it out for X={1,2,3} and tell me what members of X are in Y_f.
{1,2,3} are in Y_f because f(1) implies 1 is in it, f(2) implies 2 is in it and f(3) implies 3 is in it right?
Right. So Y_f=X={1,2,3}. Does the same thing work for every set?
it should
hocuspocus102 said:
it should
It does. x is never in X/{x}.
so Y_f is just X?
hocuspocus102 said:
so Y_f is just X?
What do YOU think? That's a lot more important than what I think.
that's what I think
hocuspocus102 said:
that's what I think
I agree.
ok. Thank you very much!
  • · Replies 19 ·
