Acceleration of Falling Object: -9.8 or +9.8?
  • Thread starter Thread starter saiyajin822
The discussion revolves around determining the appropriate sign for the acceleration due to gravity, -9.8 m/s² or +9.8 m/s², in the context of a ball being thrown from a height. Participants explore how the choice of coordinate system affects the sign of acceleration when analyzing motion in physics.
  • Participants discuss the implications of different coordinate systems on the sign of gravitational acceleration, questioning whether it should be negative or positive based on the direction of the throw and the defined axes.
The conversation is ongoing, with various perspectives on how to assign signs to acceleration based on the chosen coordinate system. Some participants suggest that consistency in sign assignment is crucial, while others emphasize the common practice of defining upward as positive.
There is an exploration of how different setups, such as throwing the ball upward or downward, influence the values assigned to initial velocity and acceleration. The discussion also touches on the importance of defining a clear point of reference in the analysis.
saiyajin822
how can you tell when to use -9.8m/s^2 or +9.8 as your acceleration for a falling object? i have a problem that says " A ball is thrown upward from the top of a 25 m tall building." would that be -9.8 since the ball is being thrown up(+) and gravity is pulling it down?(-)
Since gravity pulls objects downward that would be -9.8 m/s^2 independent of which way the ball is thrown.
It depends on your coordinate system. If distance is defined to increace up, g will be negative.
but if it says a ball is thrown *downward* at 25m/s that would be a positive g then??
Depending on whether you have assigned your point of reference and coordinate system as "Down" = "-" and "Up" = "+" or the other way around. If the ball is thrown downward, chances are all your values (or most) will be negative, so it is easier to make Down as a negative value on the coordinate system. Therefore, in that case, g will be +.
Right. As long as you are consistent throughout the problem in assigning signs to vectors according to whichever directions you defined as + or -, you will be fine.
However, most people, I think, would still choose their coordinate system with + upward and x= 0 on the ground. Then g= -9.8 m/s2 and, with the ball thrown downward, initial velocity -25 m/s.
That is, to determine the time in which a ball thrown downward at 25 m/s we would take initial speed -25m/s and initial height to be 25m and solve
-4.9t2+ 25t+ 25= 0.
Taking, as you suggest, the + axis downward we would probably take 0 to be at the top of the building, the ground to be 25 and solve 4.9t2+ 25t= 25.
I prefer to do this: the vector [tex]\vec g[/tex] is the freefall acceleration vector pointing downward [toward the center of the earth]. Its magnitude is (using the convention of leaving off the arrowhead) [tex]g=9.8{\rm\ m/s^2}[/tex] (a non-negative quantity).
Now, the "sign" you seek is carried by the component of [tex]\vec g[/tex] along an axis of your choice.
If you call "upward" the "positive direction", then the component of acceleration along this axis is [itex]a_y= - g[/itex].
If you call "downward" the "positive direction", then the component of acceleration along this axis is [itex]a_y= + g[/itex].
thx u all !
  • · Replies 38 ·
