Solving an IVP Problem: dx/dt, x(0) & Equilibrium Points
  • Context: Graduate
  • Thread starter Thread starter Tryingtolearn
    Ivp
The discussion revolves around solving an initial value problem (IVP) related to a differential equation. Participants explore the uniqueness of solutions, identify equilibrium points, and analyze the behavior of the function in terms of initial velocity and whether the distance is increasing or decreasing. The focus is primarily on mathematical reasoning and integration techniques.
  • Homework-related
  • One participant presents the IVP as dx/dt = -(1-(1/x))*(1/(x^.5)), x>1, with initial condition x(0) = 2, and seeks help with unique solutions, equilibrium points, initial velocity, and distance behavior.
  • Another participant rewrites the equation as dx/dt = -(x-1)/x^1.5 and suggests integrating both sides to find solutions.
  • A different participant expresses confusion over the algebraic manipulation leading to the rewritten form and struggles with the integration process.
  • Another reply attempts to clarify the algebra by breaking down the fractions and confirming the negative sign in the expression, asking if the resulting form can be integrated.
Participants do not reach a consensus on the algebraic manipulation of the differential equation, with some expressing confusion and others attempting to clarify. The discussion remains unresolved regarding the integration process and the correctness of the rewritten equation.
There are unresolved steps in the algebraic manipulation and integration process, and participants have differing interpretations of the expressions involved.
Tryingtolearn
I'm trying to solve an IVP problem but have not had a lot of Diff Eq to really understand this.
The IVP is
dx/dt = -(1-(1/x))*(1/(x^.5)) , x>1
x(0) = 2
I guess some of the things I'm looking for with this is:
Any unique solutions
equilibrium points
Initial velocity
distance increasing or decreasing
Any additional help on how to solve this would be very much appreciated.
Thanks in advance.
We can write dx/dt= -(1-(1/x))*(1/x^.5)) as -(x- 1)/x^1.5)
There is not t on the right so we can write this in differential form as
- x^1.5/(x-1)dx= dt.
Now integrate both sides to find the solutions.
The rest are even easier. An "equilibrium point" is a point where x doesn't change: the derivative is 0: dx/dt = -(1-(1/x))*(1/(x^.5)) = 0. Solve that equation for x.
distance (x) is increasing where the derivative is positive and decreasing where it is negative. Since you have a formula for dx/dt, that should be as easy as determining where it was 0.
I'm sorry, I guess I don't see how -(1-(1/x))*(1/x^.5)) is the same as -(x- 1)/x^1.5). I've been straining with with algebra but I just don't see that.
If it is -(x- 1)/x^1.5 then I'm at a loss for how to integrate this.
Thanks.
Subtract the fractions: 1- 1/x= x/x- 1/x= (x-1)/x. Now multiply by (1/x.5): (x-1)/(x*x.5)= (x-1)/(x1.5). All that's missing now is the negative sign.
-(x-1)/x1.5= -(x/x1.5-1/x1.5)= -x1-1.5+x-1.5= -x-.5- x-1.5. Can you integrate that?
