Equilibrium at Constant Velocity
The problem involves a helicopter in horizontal motion at constant velocity, analyzing the forces acting on it, specifically the lift force, weight, and air resistance. The subject area pertains to equilibrium and forces in physics.
  • Exploratory, Assumption checking
  • The original poster attempts to resolve the forces acting on the helicopter by breaking them into components and setting up equations for equilibrium. Some participants question the correctness of the component assignments for the lift force.
The discussion has seen some productive exchanges, with one participant providing clarification that helped the original poster. However, there is no explicit consensus on the overall approach or final solution.
The original poster expresses difficulty in obtaining the correct answers despite following a methodical approach, indicating potential misunderstandings in the setup of the problem.
BlackMamba
Hey there,
I have a problem that seems easy to me to solve but I'm just not getting it. I'll give the problem and then what I've done so far.
A helicopter is moving horisontally to the right at a constant velocity. The weight of the helicopter is W = 51200N. The lift force L generated by the rotating blade makes an angle of 21.0 degrees with respect to the vertical.
(a) What is the magnitude of the lift force?
(b) Determine the magnitude of the air resistance R that opposes the motion.
So I started out by drawing my free body diagram, making my component vector chart.
I have 3 forces acting on the helicopter; L, W, and R
For the L force:
x component = Lcos21.0 degrees
y component = Lsin21.0 degrees
For the W force:
x component = 0
y component = - W
For the R force:
x component = - R
y component = 0
So when adding up my x components my equation looks like:
Net force of x = Lcos21.0 degrees - R
and my equation for the y component looks like:
Net force of y = Lsin21.0 degrees - W
But when solving for these equations I don't get the right answer. Where am I going wrong?
Thanks for any help provided.
For the L force:
Answer : Suppose to be the other way round.
Well, thank you Leong. That did it. Unbelievable that something like that was giving me grief.
Thanks again.
Glad i can help.
  • · Replies 35 ·
  • · Replies 31 ·
