Chemistry, Equilibrium Constant Question
The discussion focuses on calculating the amount of NaOH required to create a buffer solution with a pH of 7.80 from 0.70 M HClO. The key calculation involves using the Henderson-Hasselbalch equation, which determines the ratio of the weak base (ClO-) to the weak acid (HClO). The derived ratio is 2.19, leading to the conclusion that 0.240 moles of NaOH must be added to achieve the desired buffer conditions.
  • Understanding of buffer solutions and their components
  • Familiarity with the Henderson-Hasselbalch equation
  • Knowledge of weak acids and their conjugate bases
  • Basic stoichiometry in chemical reactions
  • Study the Henderson-Hasselbalch equation in detail
  • Learn about buffer preparation and its applications in chemistry
  • Explore the properties of weak acids and their conjugate bases
  • Investigate the effects of pH on chemical equilibria
Chemistry students, laboratory technicians, and educators involved in teaching acid-base chemistry and buffer solutions.
jaguar7
Haha --- nvm, found it. Sorry/Thanks... ^_^
Where does the 2.19 come from?
How many moles of NaOH would need to be added to 500.0 mL of 0.70 M HClO to create a buffer with a pH of 7.80?
Initially, we have 0.35 mol of HClO. We are going to add NaOH which will react with the weak acid to create the conjugate weak base.
HClO + OH- → H2O + ClO-It is this weak base we’ll need to have for the buffer. First, let’s find the ratio of the weak base to the weak acid using the Henderson-Hasselbalch equation:
7.80 = -log(3.5*10^(-8) + log(base/acid)
base/acid = 2.19
Since we will be making base from the weak acid, we will react x moles of OH-. So after the reaction takes place, we have 0.35 – x moles of acid and x moles of base.
x / (0.35 - x) = 2.19
x = 0.240 moles
Won't hurt if you will explain what you were asking for and what you have found. I guess I can guess, not so sure about others.
  • · Replies 16 ·
