Work Done in moving the plates of a Capacitor
The discussion revolves around the work done when moving the plates of a parallel plate capacitor connected to a battery. Participants explore whether this work is positive or negative, considering the effects on capacitance, charge, and energy stored in the capacitor.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants discuss the relationship between capacitance, stored energy, and the work done by both the external agent and the electric field. Questions arise about the source of charge and the implications of moving the plates closer together.
The conversation includes various interpretations of the work done by the external agent versus the work done by the battery. Some participants suggest that the work done by the electric field is negative, while others question this assumption and explore the implications of the plates moving under the influence of the electric field.
There is an ongoing examination of the assumptions regarding the nature of work done by the external agent and the battery, as well as the conditions under which the plates are moved. The discussion reflects a lack of consensus on the sign of the work done and the roles of different forces involved.
zorro
Consider a parallel plate capacitor connected to a battery. You move the plates closer to each other. Will you do positive or negative work?
As the plates are moved closer to each other, capacitance increases which increases the stored energy (V is constant). We know that electrostatic potential energy is defined as the negative of the work done by the electric field. Ufinal - Uinitial is positive in this case. So work done by field is negative. Therefore work done by external agent (us) should be positive.
BUT THE ANSWER IS NEGATIVE WORK! please help
The voltage is constant and the capacitance is increased. That means increased charge. Where does this charge come from?
ehild
The extra charge comes from the work done by the person in moving the plates closer. The problem is to find out the sign of work done.
The charge does not come from the work of the person, but from the battery. The work changes the distribution of the charge.
ehild
So the battery in supplying charges does positive work. Does it mean that the person does negative work?
If yes then what is wrong with the explanation I gave in attempt at solution.
Why is the work of the field negative? What if the positive plate of the capacitor is released and let move towards the negative plate. Will not it move by itself? The electric fields points in the direction of displacement. So the work of the field is positive.
ehild
If the plates move by themselves, we are not doing any work in bringing them closer.Are we?
May be we do some work to stop the plates from getting in contact with each other. Is it right?
Yes. But usually it is assumed that the person exerts so much force that the whole process is quasi-stationary, with no change of kinetic energy. And as the person exerts force opposite to the force of electric field, its work is negative.
ehild
Thanks!
The change of the electric energy of the whole system consisting of the battery and capacitor is equal to the external work if there are no other kinds of energy involved as kinetic energy or internal energy (increase of temperature). The energy of the capacitor Ec really increases if the separation of the plates decreases. ΔEc=1/2 ΔC V2. At the same time, the charge increases on the plates by ΔQ=ΔC V. This charge is supplied by the battery, where the chemical forces do work when separate the positive and negative charges. This work of the battery is Wb=ΔQ V. The external work is the sum of that of the person and that of the battery. ΔEc=Wp+Wb, 1/2 ΔC V2=Wp+ΔC V2, Wp=-1/2 ΔC V2.
ehild
Thanks!
That was much more clear.
  • · Replies 31 ·
  • · Replies 18 ·
  • · Replies 20 ·
