New Reply
How to write a data file in Python
Share Thread Thread Tools
Nov18-10, 04:54 PM   #1
Hi guys
I've done a Runge-Kutta script for the Lorenz Equations in python, I need to write data for (t,x,y,z) in a .dat file in order to reprint in a table. How can a do it?
Imported routines are:
import sys, pylab, numpy
from pylab import *
from mpl_toolkits.mplot3d import Axes3D
from numpy import *
import matplotlib.pyplot as plt
Mi iteration code is:
for n in xrange(0,N):
# at each time step calculate new x(t),y(t),z(t)
# and append to lists x0, y0, z0
x,y,z = RKTwoD(x0[n],y0[n],z0[n],VDPXDot,VDPYDot,VDPZDot,dt)
x0.append(x)
y0.append(y)
z0.append(z)
t.append(t[n] + dt)
savetxt('output.dat', (t,x0,y0,z0))
But it doesn't work, file just contain six columns instead of four and it takes too long to execute the script.
Please can anyone help me?
Thank you
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Nov30-10, 01:15 AM   #2
If you keep everything as an array instead of a list, basically take
x0.append(x)
y0.append(y)
z0.append(z)
and do a vstack or hstack at the end
so table = hstack(x0,y0,z0)
then you just need to write out
table.tofile('output.dat')
numpy lists don't write out straight to dats
Nov30-10, 03:19 PM   #3
Thanks for your answer but it doesn't work
I'm trying
Code:
from pylab import *
from numpy import *
#I'll use values of sigma = 6.0, beta = 3.0 and rho = 36
# The Lorenz Equations are dx/dt=sigma*(y-x) ; dy/dt=x*(rho-z)-y ; dz/dt=x*y-beta*z
def VDPXDot(x,y,z):
	return 6.0 * (y-x)
def VDPYDot(x,y,z):
	return x * (40.0 - z)- y
def VDPZDot(x,y,z):
	return x * y - 3.0 * z
# 3D Fourth-Order Runge-Kutta Integrator
def RKTwoD(x,y,z,f,g,m,dt):
	#9 operaciones
        k1x = dt * f(x,y,z)
	k1y = dt * g(x,y,z)
        k1z = dt * m(x,y,z)
	#15 operaciones
        k2x = dt * f(x + k1x / 2.0,y + k1y / 2.0,z + k1z / 2.0)
	k2y = dt * g(x + k1x / 2.0,y + k1y / 2.0,z + k1z / 2.0)
        k2z = dt * m(x + k1x / 2.0,y + k1y / 2.0,z + k1z / 2.0)
        #15 operaciones
        k3x = dt * f(x + k2x / 2.0,y + k2y / 2.0,z + k2z / 2.0)
	k3y = dt * g(x + k2x / 2.0,y + k2y / 2.0,z + k2z / 2.0)
        k3z = dt * m(x + k2x / 2.0,y + k2y / 2.0,z + k2z / 2.0)
	#12 operaciones
        k4x = dt * f(x + k3x,y + k3y,z + k3z)
	k4y = dt * g(x + k3x,y + k3y,z + k3z)
        k4z = dt * m(x + k3x,y + k3y,z + k3z)
        #12 operaciones
	x = x + ( k1x + 2.0 * k2x + 2.0 * k3x + k4x ) / 6.0
	y = y + ( k1y + 2.0 * k2y + 2.0 * k3y + k4y ) / 6.0
        z = z + ( k1z + 2.0 * k2z + 2.0 * k3z + k4z ) / 6.0
	return x,y,z
dt = 0.002
x0 = [0.0]
y0 = [1.0]
z0 = [0.0]
t  = [0.0]
N = 20000
  x0.append(x)
  y0.append(y)
  z0.append(z)
 t.append(t[n] + dt)
  m1 = array(x0)
  m2 = array(y0)
  m3 = array(z0)
  m4 = array(t)
  m1.tofile("putamierdax.dat", sep='\n', format = "%e")
  m2.tofile("putamierday.dat", sep='\n', format = "%e")
  m3.tofile("putamierdaz.dat", sep='\n', format = "%e")
It works but the script time is too long and I've got to work with three files
Nov30-10, 03:25 PM   #4
Mentor
My understanding is that Python is an interpreted language, so if you have a loop that runs for many iterations, it's going to take a long time. The way around that is to use a language that is compiled, such as C or C++.
I don't know enough about Python to say anything intelligible about your file I/O problem...
Nov30-10, 04:59 PM   #5
Thanks for your answer Mark44
No matter if the script takes too much time (I'm doing the script also for C++ and Java), but there must be some way to save all data in a unique file. By splitting it in four I have to use Ultraedit and it's a bit tiring..
Nov30-10, 05:34 PM   #6
look into numpy.savetxt(...)
Dec1-10, 08:08 PM   #7
Sorry, I gave you the wrong args. It should be:
table = hstack([x0,y0,z0,t])
but when you open it, you need to specify the size of the array and make sure it's saved and unpacked as the right type.
you can also look into scipy.io.savemat
Quote by javiergra24 View Post
I just ran your script and it took supershort, so I'm thinking the bug is that you're running this:
Code:
  m1 = array(x0)
  m2 = array(y0)
  m3 = array(z0)
  m4 = array(t)
in the for loop.
Dec8-10, 03:46 PM   #8
Quote by story645 View Post
Code:
  m1 = array(x0)
  m2 = array(y0)
  m3 = array(z0)
  m4 = array(t)
in the for loop.
How can I run the data saving script outside the for loop?
Thank you
Dec8-10, 04:26 PM   #9
Just unindent it, so:
Code:
    x0.append(x)
    y0.append(y)
    z0.append(z)
    t.append(t[n] + dt)
m1 = array(x0)
m2 = array(y0)
m3 = array(z0)
m4 = array(t)
[/code]
Dec9-10, 04:32 AM   #10
Code:
    x0.append(x)
    y0.append(y)
    z0.append(z)
    t.append(t[n] + dt)
m1 = array(x0)
m2 = array(y0)
m3 = array(z0)
m4 = array(t)
[/code]
Thank you very much!! So simple and I didn't notice
New Reply
Thread Tools
Similar Threads for: How to write a data file in Python
Thread Forum Replies
Fortran 95: WRITE to screen changes output to WRITE to file Programming & Comp Sci 13
Write an exponential equation from this data (data table included) Precalculus Mathematics Homework 2
Write an is_prime function in Python Engineering, Comp Sci, & Technology Homework 1
loading file in python shell Programming & Comp Sci 1
Loading a file (module) in Python Computing & Technology 6
