What is the % ionisation of hypochlorous acid in a 0.015M solution at 25°C?
  • Thread starter Thread starter NOP90
    Chemistry
The % ionisation of hypochlorous acid (HClO) in a 0.015M solution at 25°C is calculated to be 0.14%. The acid dissociation constant (Ka) for HClO is 3.0 x 10^-8. The calculation involves setting up an equilibrium expression using the formula \(\frac{{[x][x]}}{{0.015 - x}} = Ka\), where x is the concentration of ionized HClO. The discussion highlights the use of ICE tables for solving equilibrium problems.
  • Understanding of acid dissociation constants (Ka)
  • Familiarity with equilibrium expressions in chemistry
  • Knowledge of ICE (Initial, Change, Equilibrium) tables
  • Basic logarithmic calculations for pH and ionisation
  • Study the application of ICE tables in equilibrium calculations
  • Learn how to derive and use the Henderson-Hasselbalch equation
  • Explore the concept of weak acid ionisation and its implications in buffer solutions
  • Investigate the effects of concentration changes on the % ionisation of weak acids
Chemistry students, educators, and anyone studying acid-base equilibria, particularly those focusing on weak acids and their ionisation properties.
NOP90
The Ka of hypochlorous acid (HClO) is 3.0*10^-8 at 25 degrees C. What is the % ionisation of hypochlorous acid in a 0.015M aqueous solution of HClO at 25 degrees celsius
The answer is 0.14
-log[H+], n = cV, pH = pKa + log (base/acid), x/y*100=%
I tried -log3*10^-8 and got 7.5. Not to sure what to do with that.
Was the "0.015" actually the FORMAL concentration of the acid? If we assume that the concentration really was meant as 0.015M of the weak acid, then
[tex]\[<br /> \frac{{\left[ x \right]\left[ x \right]}}{{0.015 - x}} = Ka = 3 \times 10^{ - 8} <br /> \][/tex], where x represents approximately the amount of moles per liter of HClO which actually ionizes.
NOP90, have you heard about ICE tables?
  • · Replies 16 ·
