Taylor Series of the inverse tangent function
The discussion revolves around finding the 2005th derivative at zero of the function f(x) = tan-1((1+x)/(1-x)), within the context of Taylor Series expansions. Participants are exploring the properties and calculations related to Taylor Series, particularly for the inverse tangent function.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are attempting to relate the Taylor Series of arctangent to the specific function given. There are discussions about substituting variables and determining coefficients for specific derivatives. Some participants suggest starting with simpler cases to build understanding.
The conversation is ongoing, with various interpretations and approaches being explored. Some participants have offered hints and suggestions for further investigation, particularly regarding the relationship between derivatives of the functions involved.
There is a noted confusion regarding the nature of f(2005)(0) as a specific value versus a function of x. Participants are also considering the implications of substituting values into the Taylor Series and the need to expand series properly to find specific coefficients.
kudoushinichi88
I have a shaky understanding of problems concerning Taylor Series. For example, the question below.
Let [itex]f(x)=\tan^{-1}\left(\frac{1+x}{1-x}\right)[/itex] where [itex]-\frac{1}{2}\leq x \leq \frac{1}{2}[/itex]. Find the value of
[tex]f^{2005}(0)[/tex]
the Taylor Series of [itex]\tan^{-1}[/itex] is
[tex]\sum_{n=0}^{\infty}\frac{(-1)^nx^{2n+1}}{2n+1}[/tex]
my friend told me to set [itex]k=2n+1[/itex] and after an attempt to solve this, I got
[tex]f^{2005}(0)=\left(\frac{1+x}{x(1-x)}\right)^{2005}(2004!)[/tex]
I'm not sure if I'm doing this right.
What you have doesn't even make sense. The left side, [itex]f^{2005}(0)[/itex], is a specific number, not a function of x.
Given that the Taylor's series for arctangent is
you can then replace that x with [itex](1+ x)/(x(1- x))[/itex] but then you have to expand that to get a power series and determine n so that x has power 2005.
[itex]f^{2005}(0)[/itex] is the coefficient not entire term.
May I add something too please? I would suggest he first solve the problem for just arctan(u), just that one, say for the fourth or fifth or like me, the seventh derivative. Get that straight, then go for the other one. So:
[tex]f(u)=\arctan(u)=\sum_{n=0}^{\infty} \frac{f^{(n)}(0)}{n!} u^n=\sum_{n=0}^{\infty} \frac{(-1)^n u^{2n+1}}{2n+1}[/tex]
See, that's already a good start. Then that means:
[tex]\frac{f^{(2n+1)}(0)}{(2n+1)!}=\frac{(-1)^n}{2n+1}[/tex]
or:
[tex]f^{(2n+1)}(0)=(-1)^n \frac{(2n+1)!}{2n+1}[/tex]
Now, here's the very important part I wish to emphasize: check that in Mathematica, say for the seventh derivative. Then in that case, n=3 right? so:
Code:
In[18]:=
D[ArcTan[x], {x, 7}] /. x -> 0
N[((-1)^3/7)*7!]
Out[18]=
-720
Out[19]=
-720.
Now, here's a hint to solve your problem, take:
[tex]\frac{d}{du} \arctan(u)[/tex]
and:
[tex]\frac{d}{dx}\arctan(\frac{1+x}{1-x})[/tex]
What do you notice about the two derivatives and then all the other higher order derivatives?
So... subbing [itex]\frac{1+x}{1-x}[/itex] into,
[tex] \sum_{n=0}^{\infty}\frac{(-1)^nx^{2n+1}}{2n+1}[/tex]
I have
[tex] \sum_{n=0}^{\infty}\frac{(-1)^n\left(\frac{1+x}{1-x}\right)^{2n+1}}{2n+1}[/tex],
By setting [itex]2n+1=2005[/itex], and comparing with the general representation of a taylor series,
[tex] \sum_{n=0}^{\infty}\frac{f^n(a)}{n!}(x-a)^n[/tex]
I finally got
[tex]\frac{1002!}{2005}[/tex]
Is this correct?
No, that's not correct. I would strongly recommend you consider jackmell's hint about comparing the first derivatives of those two functions.
  • · Replies 27 ·
