Why Does Shaking a Soda Can Cause an Explosion?
  • Thread starter Thread starter dEdt
    Cause Explosion
The discussion revolves around the phenomenon of a soda can "exploding" when shaken, exploring the underlying physical principles, including gas solubility, pressure dynamics, and nucleation processes. Participants examine various explanations and theories related to the agitation of the liquid and its effects on dissolved gases, as well as the implications of pressure changes within the can.
  • Some participants propose that shaking a soda can increases the kinetic energy of the liquid and gas, making it harder for gas molecules to remain dissolved.
  • Others argue that the amount of gas dissolved in the liquid is dependent on pressure according to Henry's law, and that agitation affects the speed of dissolution rather than the concentration of dissolved gas.
  • A participant suggests that the pressure inside the can increases with depth, which could lead to gas bubbles forming when the liquid rises to lower pressure areas after shaking.
  • Another viewpoint emphasizes that the CO2 in the liquid exerts pressure only when in the gas phase above the liquid, challenging the idea that dissolved CO2 contributes to pressure.
  • Some participants discuss the concept of oversaturation and nucleation, questioning whether agitation leads to irreversible processes or if gas can return to solution when left undisturbed.
  • One participant explains that nucleation processes, such as the formation of fine bubbles during shaking, can accelerate the release of CO2 when the can is opened.
  • Questions are raised about the pressure conditions in unopened cans, both shaken and unshaken, and the safety measures in place to prevent explosions.
Participants express multiple competing views on the mechanisms behind the "explosion" of a shaken soda can, with no consensus reached on the primary factors involved. The discussion remains unresolved, with various hypotheses being proposed and challenged.
Participants highlight limitations in understanding the relationship between agitation, pressure, and gas solubility, as well as the effects of temperature and prior conditions on the state of the liquid and gas. Specific mathematical or experimental details are not fully explored.
This discussion may be of interest to those studying physical chemistry, fluid dynamics, or anyone curious about the behavior of gases in liquids under varying conditions.
dEdt
Why does a can of soda "explode" when it's shaken? I looked online, but all the explanations were either very hand-wavy, or looked very wrong. Thanks!
Chemistry news on Phys.org
CO2 is dissolved in the liquid. Liquids cannot dissolve as much gas when the liquid is agitated.
This concept is used in labs all the time. Gas can be removed from a liquid by shaking it at high speeds using ultrasound.
Best explanation I've heard is that shaking increases the kinetic energy of both the liquid and the gas. When the molecules are moving around faster, it's harder for them to grab each other. This makes sense because it's exactly what happens when a liquid is heated - hot liquids dissolve less gas.
Doesn't sound completely right to me.
Amount of gas dissolved in the liquid doesn't depend on whether the liquid is agitated or not. Speed of dissolution depends on the agitation, but concentration in a given temperature depends only on the pressure (Henry's law). Whatever happens when the can is shaken seems to be effect of oversaturation and nucleation.
When the solution is sonificated situation is a little bit different. Sonification produces high pressure gradients - in some places pressure in the solution is very high, in other very low. Where the pressure is low, gas can form bubbles. They get dissolved back, but as they tend to go up, they slowly leave the solution.
Borek, I think I may come up with a partial explanation.
The pressure inside the can increases with depth, so the lower portions of the can should hold more gas than the shallower parts. If the can is shaken, then conceivably the liquid from the bottom would rise to a point of lower pressure. Then, the pressure might not be enough to keep the gas in suspension, and bubbles would form. I don't know how this would lead to the can exploding, but I feel it's important. I read somewhere that whirlpools might play a role as well, but the explanation was very poor.
Axillary question: why does tapping the can help?
The explanation I was given is that the CO2 in the liquid exerts a certain pressure per unit area of the surface. In shaking the liquid the surface area of the liquid increases dramatically and so does the total pressure.
But the can will still explode once the drink settles and the surface resumes its normal shape.
Pressure difference is negligible.
Gas is not suspended but dissolved, not sure what you are aiming at.
Please elaborate.
That looks so wrong I have no idea where to start. First of all, dissolved CO2 doesn't exert any pressure, pressure is exerted by the gas above the liquid. Total FORCE exerted by the pressure depends on the surface, but pressure does not. And surface that is important here - internal surface of the can - is constant.
When something is in a oversaturated condition and some agitation causes it to crash out, isn't that usually a process that doesn't reverse itself? If I boil some water, dissolve salt in it, start to cool it. It's oversaturated. I tap the glass and the salt crashes out. If I leave it at that temperature, it doesn't go back to being oversaturated. With the soda can, the gas does go back into solution if left alone.
It's perfectly soluble as long as it's not being agitated, and it returns to this state when left alone. There's just something about shaking it that dramatically lowers solubility.
It won't. When people pop open a bottle of bubbly wine, they will often tap the glass with a spoon to build pressure. That's also a jerk move to do to someone's beer; tap the side of it when they leave the table so it goes flat very quickly.
Never stated that. I guess what happens is that whether there is a sharp rise in the pressure after shaking the can or not depends on the can history. If it was kept in cold place and later allowed to warm up, it can be oversaturated, if it was warm all the time (or since it was shaken), pressure inside is constant.
It's about nucleation and pressure. At the high pressure in the can before you open it, the CO2 is in eqilibrium between the gas phase and liquid. Opening the can lowers the pressure and puts the CO2 dissolved in the liquid out of equilibrium. CO2 starts to come out. The speed at which it comes out depends on any nucleation processes that might accelerate it like producing lots of fine bubbles when the can is shaken. These small bubbles adhere to the walls of the container and stick. Opening the can causes a rapid nucleation and effervescence. Tapping the walls of the can and waiting for the fine bubbles to dislodge, float to the surface and pop (all three!) will reduce the tendency to vigorously effervesce. But you have to wait for the small bubbles to rise to the surface and pop, otherwise it will still foam. If you don't tap hard enough, the bubbles won't dislodge at all.
Try it yourself and see.
Does anyone know:
1. What is the pressure in an un opened can at room temperature and in an unshaken condition?
2. What is the pressure in an un opened can at room temperature when it is "shook up"?
Soda can bottlers and can manufacturers must know about this or there would be exploding cans all over the place. There has to be a reasonable factor of safety on this sort of thing.
Sounds like one for Myth Busters...
  • · Replies 46 ·
10K
  • · Replies 20 ·
9K
  • · Replies 43 ·
10K
