Find T(v) by using the standard matrix and the matrix relative to B and B'
The discussion revolves around finding a transformation matrix T: R^2 --> R^3 defined by T(x,y) = (x+y,x,y) relative to two bases B and B'. The bases are given as B = {(1,-1),(0,1)} and B' = {(1,1,0),(0,1,1),(1,0,1)}. Participants are exploring how to express the transformation in terms of these bases and are comparing their findings with an example from a textbook.
  • Mixed
  • Participants are attempting to calculate the transformation matrix by expressing the outputs of T(v1) and T(v2) as linear combinations of the basis vectors in B'. There are discussions about the correct coefficients and the resulting matrices. Some participants question the correctness of their calculations and the interpretation of the example provided in the textbook.
There is ongoing exploration of the transformation matrix and its components. Some participants have provided guidance on how to express vectors in terms of the basis vectors, while others are questioning the validity of their results and the example in the textbook. Multiple interpretations of the problem are being discussed, and participants are actively seeking clarification on their approaches.
Participants note potential confusion stemming from differing interpretations of the transformation process and the example in the textbook. There are mentions of specific calculations leading to perceived errors, as well as discussions about the dimensionality of the matrices involved.
RET80
Basically I need to find an equation that is relative to both B and B'
T: R^2 --> R^3, T(x,y) = (x+y,x,y)
B = {(1,-1),(0,1)}
B' ={(1,1,0),(0,1,1),(1,0,1)}
THE ONLY example from the book (Elementary Linear Algebra by Larson and Falvo)
6.3 Example 5
Let T: R^2 --> R^2
T(x1, x2) = (x1+x2, 2x1-x2)
Find the matrix for T relative to the bases:
B ={(1,2),(-1,1)}
B'={(1,0),(0,1)}
By the definition of T, you have:
T(v1) = T(1,2) = (3,0) = 3(w1) + 0(w2)
T(v2) = T(-1,1) = (0, -3) = 0(w1) - 3(w2)
The coordinate matrices for T(v1) and T(v2) relative to B' are
[T(v1)]B' = (3, 0)
[T(v2)]B' = (0, -3)
The matrix for T relative to B and B' is formed by using these coordinate matrices as columns to produce:
A =
[3 0]
[0 -3]
B = {v1, v2}
B' = {w1, w2, w3}
T(v1) = T(1,-1) = (0,1,1) = 0(w1) + 1(w2) + 1(w3) = (-1, 1, 0)
T(v2) = T(0,1) = (1,0,1) = 1(w1) + 0(w2) + 1(w3) = (2, 1, 1)
[T(v1)]B' = (-1, 1, 0)
[T(v2)]B' = (2, 1, 1)
Which creates the matrix:
[-1 2]
[1 1]
[0 1]
Apparently this matrix is incorrect, but the example in the book (which is given in part 2) states that, this should be the process, I am very lost and confused and have spent a good four hours on this single problem, trying to understand the concept
B = {(1,-1),(0,1)}
6.3 Example 5
Let T: R^2 --> R^2
B ={(1,2),(-1,1)}
B'={(1,0),(0,1)}
[T(v1)]B' = (3, 0)
[T(v2)]B' = (0, -3)
A =
[3 0]
[0 -3]
B = {v1, v2}
B' = {w1, w2, w3}
You made a small mistake calculating T(1,-1); it should be (0,1,-1).
The reason it's not working is because you've misinterpreted what they did in the example. The idea is to express each vector as a linear combination of w1, w2, and w3. In other words, find c1, c2, and c3 such that
(0,1,-1) = c1w1+c2w2+c3w3
and likewise for the second vector. These coefficients then become the columns of the matrix.
[-1 2]
[1 1]
[0 1]
When I used c1w1 + c2w2 + c3w3 = v1 and v2 I got...
v1
c1 + c3 = 0
c1 + c2 = 1
c2 + c3 = -1
which then reduced down to the matrix:
[1 0 0 | 1]
[0 1 0 | 0]
[0 0 1 | -1]and v2
c1 + c3 = 1
c1 + c2 = 0
c2 + c3 = 1
[1 0 0 | 0]
[0 1 0 | 0]
[0 0 1 | 1]
then I put both v1 and v2 together
[1 0]
[0 0]
[-1 1]
which still isn't correct...Is there something I'm missing or did I go wrong somewhere in my row reduction?
or does it have to do with [T(v)]B' ?
What I'm basically going to do after this is find T(v)
in the problem v is given to me as v=(5,4)
so I use B = (1,-1),(0,1)
and do a linear combination with it such as...
v = (5,4) = c1(1,-1) + c2(0,1)
c1 = 5
-c1 +c2 = 4
which reduced down to a matrix:
[1 0 | 5]
[0 1 | 9]
so then [v]B = (5,9)
then I multiply A[v]B to get my final answer which SHOULD be (9,5,4)
So I HAVE [v]B I just don't think I have A yet.
That's the correct answer for the problem you described. Why do you think it's wrong?
the answer is 9, 5, 4 in the book but I'm getting 5, 0 4
if I multiply:
[1 0] [5]
[0 0] [9]
[-1 1]
I get (5,0,4) which is wrong...
Your book is wrong. You can write the transformation T as
[tex]T\begin{bmatrix}x\\y\end{bmatrix} = \begin{bmatrix}x+y\\x\\y\end{bmatrix} = x\begin{bmatrix}1\\1\\0\end{bmatrix}+y\begin{bmatrix}1\\0\\1\end{bmatrix}[/tex]
Note the two constant vectors are first and third vectors in basis B'. That means the image of T can't include any vector where c2 isn't equal to 0, so (9, 5, 4) can't possibly be what (5, 9) maps to.
I am also on the same problem. Part A asks to find T(v) using the standard matrix.
T: R^2 --> R^3, T(x,y) = (x+y,x,y), v = (5,4)
so A =
[ 1 1 ;
1 0 ;
0 1 ]
and Av = (9,5,4) which is the answer given in the back of the book. So since the problem basically asks you to find A in 2 different ways (standard vs basis), shouldn't the book be right?Wait wait never mind, you are right vela, my prof attempted to do it a couple days ago, the book is wrong.
You're using a different vector than RET80. Which one is the correct one?
Your matrix A, which is 3x3, can't possibly be correct. You can't multiply it by a 2-component vector. The dimensions don't work out.
The A in my previous post is a 3x2, multiplied by a 2x1(v)
so A =
[1 1]
[1 0]
[0 1]
v =
[5]
[4]
Sorry I was using MATLAB notation with the semicolons.
A is found by finding the standard matrix of a linear transformation from T(x,y) = (x+y,x,y). Essentially this A matrix is what you have in post #6 with the 2 columns put together.
