Distance on arrays of unit-quaternions
  • Context: Graduate
  • Thread starter Thread starter mnb96
    Arrays
The discussion focuses on the algebra of quaternions, specifically the sub-algebra of unit-quaternions within the framework of \mathcal{C}\ell_{3,0}^+. It explores the concept of representing finite arrays of unit-quaternions as points on a manifold and confirms that such n-tuples can indeed represent points on a manifold through direct products. The computation of geodesic distance between these n-tuples depends on the chosen metric. The conversation also touches on the distinction between vectors and points in the context of manifolds.
  • Understanding of quaternion algebra and its properties
  • Familiarity with the concept of manifolds in mathematics
  • Knowledge of metrics and geodesics in differential geometry
  • Basic understanding of unit-quaternions and their representation on the \mathcal{S}^3 sphere
  • Research the properties of direct products in the context of manifolds
  • Learn about different metrics used to compute geodesic distances in manifold theory
  • Explore the relationship between unit complex numbers and manifold representations
  • Study the implications of quaternion algebra in higher-dimensional spaces
Mathematicians, physicists, and computer scientists interested in advanced topics in geometry, particularly those working with quaternions and manifold theory.
mnb96
Hello,
let's take the algebra of quaternions [itex]\mathcal{C}\ell_{3,0}^+[/itex] and consider only the sub-algebra of unit-quaternions.
When we wanted to define a https://www.physicsforums.com/showpost.php?p=2911801&postcount=6" we used the fact that unit-quaternions lie on the [itex]\mathcal{S}^3[/itex] sphere.
Now, what happens if we instead consider the whole set of finite "arrays" [itex](q_1,\ldots,q_n)[/itex], in which each entry qi is a unit-quaternion?
Is it possible that an n-tuple [itex](q_1,\ldots,q_n)[/itex] represent a point on some manifold?
If so, how can we compute the geodesic distance between two n-tuples?
Thanks!
EDIT:
a simplified question could be: given a vector of unit complex numbers, can we consider this vector as a point of some manifold?
mnb96 said:
Hello,
Yes. We can simply consider direct products. Here are some equivalent presentations:
https://www.physicsforums.com/insights/journey-manifold-su2mathbbc-part/
Depends on the metric considered.
Thanks!EDIT:
There is a difference between a vector and a point so your question is a bit unclear. Every point described via coordinates can be considered a point of a manifold. Which manifold might be the more interesting question as there is no unique answer.
  • · Replies 39 ·
14K
  • · Replies 0 ·
  • · Replies 61 ·
11K
