I need to neutralize bleach in my heating system
The discussion revolves around the neutralization of bleach in a heating system after its use to eliminate odors from ethyl mercaptan residue. Participants explore methods to ensure safe chemical interactions with sodium nitrite, a rust inhibitor, while considering the implications of dilution and potential reactions.
  • One participant describes adding bleach to a propane gas tank to eliminate odors and expresses concern about safely neutralizing the bleach before adding sodium nitrite.
  • Another participant suggests using sodium sulfite as a potential neutralizer for bleach.
  • A question is raised about the quantity of sodium sulfite needed, indicating that it depends on the amount of bleach present.
  • A participant calculates the remaining concentration of bleach after draining and refilling water, questioning whether this dilution would be sufficient to prevent a reaction with sodium nitrite.
  • There is a suggestion that while sodium nitrite may reduce bleach, sodium sulfite might be a more effective option, although the reasoning is not fully recalled.
  • Concerns are expressed about the potential for increased corrosion due to the presence of various ions in the solution after dilution.
Participants do not reach a consensus on the best method for neutralizing bleach or the safety of the remaining bleach concentration after dilution. Multiple viewpoints on the effectiveness of sodium sulfite versus sodium nitrite remain present.
Participants discuss the implications of dilution and the presence of ions in the solution, but there are unresolved questions regarding the exact reactions and safety measures needed after the dilution process.
This discussion may be of interest to individuals dealing with chemical interactions in heating systems, particularly those concerned with odor neutralization and corrosion prevention in water systems.
Igloozz
I used a propane gas tank to add thermal storage to my out door wood burner.
The ethyl mercaptan residue mixed in the water and the smell about drove us out of the house.
I added bleach to the tank which did a fair job of killing the smell, now I need to know how to neutralize the bleach so I can add rust inhibitor to the water.
We use sodium nitrite as a rust inhibitor and I don't know if it will react with the bleach residue.
I got in over my head when I starded mixing chemicals and I don't want to create a situation where I produce something dangerous.
Any input will be greatly appreciated.
Chemistry news on Phys.org
Sodium sulfite comes to mind.
How much would it take?
Depends on the amount of bleach present.
I added 6 gallons of bleach to 600 gallons of water, I can drain all but about 75 gallons.
I can refill with fresh water.
My question is will the bleach be diluted enough after I drain and refill that it won't cause
any reaction with the Sodium nitrite? Or do I still need to neutralize after I drain and refill?
So what was left is equivalent to about 6*75/600 gallons of bleach.
Nitrite will probably reduce bleach as well, but something tells me that sulfite is better. Can't remember why.
Now that I think about it - probably the best thing to do is to dilute it draining water several times as far down as possible and refilling back. While it is not a problem to reduce the chlorine from the bleach, you will be left with a solution containing many ions, such solutions speed up corrosion. That's not different from corrosion being faster in sea water than is fresh water.
That makes sense to me, I began to drain tonight, I will do some serious fill and flush tomorrow. Thank you for your input.
  • · Replies 68 ·
406K
  • · Replies 19 ·
11K
  • · Replies 130 ·
51K
