How Can I Express Wall Pressure as a Differential Equation?
  • Context: Undergrad
  • Thread starter Thread starter Mathman23
    Material
The discussion centers on expressing wall pressure as a differential equation, specifically in the context of a wall made from material Y that can withstand pressure Z, subjected to wind speeds of N miles/hour. The consensus is that a differential form is unnecessary for basic analysis unless a detailed stress analysis is required. For a comprehensive solution, the Navier-Bresse equations of Elastic Theory should be employed, alongside Finite Element Method (FEM) techniques to analyze stress and deformation throughout the wall.
  • Understanding of the Resistance of Materials principles
  • Familiarity with Navier-Bresse equations in Elastic Theory
  • Knowledge of Finite Element Method (FEM) analysis
  • Basic concepts of one-dimensional and three-dimensional stress analysis
  • Research the application of Navier-Bresse equations in structural analysis
  • Learn about Finite Element Method (FEM) for stress and deformation analysis
  • Study one-dimensional analysis techniques for bending stress in materials
  • Explore various force distributions applicable to narrow girders and their corresponding ordinary differential equations (ODEs)
Engineers, structural analysts, and students in civil engineering who are focused on stress analysis and material resilience under pressure conditions.
Mathman23
Hi
I have the following problem:
A wall has a size of X square-feet.
Is has been build by a material called Y which can withstand Z amounts of pressure.
A storm which produces winds of N Miles/hour (Equivalent to Z) blows onto the wall.
My question is:
Is it possible to express the above as a differential equation ?
So I can calculate how much pressure a wall of a certain size and material can withstand
Thanks in advance.
Sincerely
Fred
Denmark
If I understood you well, Fred, in my opinion no differential form is needed, unless you want to do an accurate stress analysis inside the wall.
You have two ways:
i) establishing equilibrium in the wall considering the laws of the Resistance of Materials. Given the pressure exerted, you will have to solve for finding the bending stress that is bearing the wall. Once you have this bending stress you will employ a withstand criterion, (i.e. the material starts to have a plastic behaviour). All of that can be done with one-dimensional analysis at one of the lines of symmetry of your wall, where surely are concentred the maximum stresses.
ii) If you want to do a three-dimensional analysis, you will have to employ the complete Navier-Bresse equations of the Elastic Theory. They will report you the stress an deformation in each point of the wall. Surely you will have to employ FEM methods.
To be honest, you ought to clarify yourself if you want an "engineering" solution, or you want a full detail solution.
Anyway, there exists ODE's for one dimensional and narrow girders bearing a lot of variety of force distributions.
Thanks for Your Answer.
What I'm looking for is a full detailed solution of ii)
Any idears of surgestions on how I do that ?
Thanks in advance Fred.
Sincerely
Fred
  • · Replies 23 ·
  • · Replies 0 ·
  • · Replies 65 ·
10K
14K
  • · Replies 19 ·
