Pulsed laser diode driver - how it works?
The discussion revolves around the operation of a pulsed laser diode driver as described in its data sheet. Participants are examining the circuit's functionality, specifically focusing on the direction of electron flow and the behavior of components within the circuit.
  • One participant describes the operation of the circuit, detailing how the capacitor charges and discharges through the output diode when a switch is closed.
  • Another participant confirms that the flow of electrons in a regular diode is from cathode to anode, aligning with the first participant's description of the circuit.
  • A participant expresses uncertainty about the accuracy of the data sheet, indicating a belief that it may contain a mistake regarding the direction of electron flow.
  • There is a query about the existence of a commercial product related to the data sheet, which is later confirmed by another participant.
Participants generally agree on the basic operation of the circuit, but there is disagreement regarding the accuracy of the data sheet's depiction of electron flow. The discussion remains unresolved regarding whether the data sheet is correct or contains an error.
Participants express uncertainty about the implications of the data sheet's claims and the potential for errors in technical documentation. The discussion does not resolve the correctness of the claims made in the data sheet.
Individuals interested in laser diode technology, circuit design, and those evaluating technical documentation for accuracy may find this discussion relevant.
McKendrigo
Hi everyone,
I've been looking at the data sheet for a pulsed laser diode driver that I've been using, and I've managed to convince myself that there's a mistake. I was hoping that if I post my explanation of how the circuit shown in the data sheet works, that you guys can either confirm that the data sheet is wrong, or (embarrassingly) tell me that I'm wrong :redface:
I've attached the circuit as shown in the data sheet. My explanation is as follows (which is more or less what the data sheet says):
When S1 is open, the capacitor Cpfn charges by the high voltage input, HV_IN, through the clamping diodes D1 and D2. The output laser diode is reverse biased in this case, so no current flows through it. When S1 is closed, D1, D2 and the output diode are effectively connected in parallel with the capacitor Cpfn. Because D1 and D2 are now reverse biased, and the output diode is now forward biased, all the charge that accumulated in Cpfn is discharged through the output diode, producing the output pulse from the laser diode.
Where I disagree with the data sheet is the direction of the arrow showing "electron flow". It shows the flow of electrons as moving from the output diode's cathode to it's anode. They seem to be depicting electrons flowing towards the negative terminals of the output diode and capacitor! Surely this arrow is pointing in the wrong direction...or have I got the wrong end of the stick?
Thanks in advance for your input!
At least in a regular diode the actual flow of electrons is from the cathode to anode, and that's also in agreement with your description of how the circuit works; i.e. the cap discharges through D3, with current flow in the direction of the arrow.
Hi,
thanks for your reply. Glad to have someone agree with me! I'm still naive enough to have this voice in my head tell me that if it's in something like a data sheet, it must be right! ;)
Hi,
Is there some commercial product according to this data sheet?
Galiupatiket said:
Hi,
Yes. It's from a commercial laser diode driver. The company is www.directedenergy.com and it's from a PCO-7110 Laser Diode Driver Module.
  • · Replies 23 ·
  • · Replies 32 ·
  • · Replies 16 ·
