| New Reply |
conception of heat storage with Na2-SO4? |
Share Thread | Thread Tools |
| Nov26-10, 11:29 AM | #1 |
Hi,
Who could evaluate my conception of heat storage with Na2-SO4? Idea: Dry Na2-SO4 is moistered with water till max energy release (solvation energy?) Has there been now Na2-SO4-10H20 produced? Can this compound be regenerated (dried) with heat supply (sun radiation?) to dry Na2-SO4? thanks taking time Johann |
| Nov26-10, 12:03 PM | #2 |
It's possible but something losing and gaining water is a bit tricky to engineer
Most systems using something going between liquid and solid form. I think the small personal ones use Sodium Acetate - don't know what you would use on an industrial scale. |
| Nov27-10, 02:01 AM | #3 |
Thanks for your bringing Natrium Acetate. As a result, there are many other alternatives i found as gypsum, activated carbon. But it is challenging to bring any of them to a competitive technique as all are limited in capacity.
| Nov29-10, 03:58 AM | #4 |
There is nothing conceptually wrong with what you describe. Heating up a hydrated crystal will drive the water off and make it anhydrous. I'm not sure how you make any of that useful, but your understanding of the chemistry is sound.
| Nov29-10, 12:05 PM | #5 |
There were some people building homes in the US out of this - you need quite a lot obviously - I think the plan was basically log cabins with lots of insulation on the outside. Your plan to hydrate a salt is workable as MagnetDave said, it's just a bit tricky to deal with the hydrated <-> crystal change in an engineering sense. How do you collect the released water without using lots of power and how do you keep the resulting crystal in a compact form while still allowing water to get back into it? You also have to consider how corrosive / toxic the material is - it's no use having a free source of energy if you need some super expensive stainless steel or titanium alloy to contain it. |
| Nov29-10, 03:46 PM | #6 |
After some evaluation, natrium-sulfate is not any more a prior material for storaging sun energy. Actually, sodium-acetate would fit better due to its higher melting point of 58°C.
However, before looking closer into sodium-acetate, i focus more on gypsum and second on activated carbon. Related features of gypsum have been described within a patent in the 80's. As a result, there are sufficient data about gypsum in regard of heat storage and release but not yet from activated carbon run with water. If someone knows how to approache such a thermo-chemical cycle with activiated carbon and water at atmospheric conditions, that would be helpful. Thanks |
| Nov29-10, 04:33 PM | #7 |
Admin
I remember reading about using magnesium sulfate heptahydrate for the same purpose.
| New Reply |
| Tags |
| enthalpy, heat storage, latent heat |
| Thread Tools | |
