New Reply
Nuclear model of Atom, O2 nucleus and speed at which a proton must be fired toward it
Share Thread Thread Tools
Nov28-10, 04:11 PM   #1
The oxygen nucleus 16O has a radius of 2.91 fm. With what speed must a proton be fired toward an oxygen nucleus to have a turning point 1.11 fm from the surface?
2. Relevant equations
Kinetic energy = 1/2 mv^2
Potential energy = 1/4(pi)Enot * q/radius min
3. The attempt at a solution
I combined the two above equations as follows:
1/4(pi)Enot * q/radius min = 1/2 mv^2
9x10^9 (1.602x10^-19)/(1.11x10^-15 m) = 1/2 (9.109x10^-31)v^2
1.688x10^18 m/s = v
The above answer was incorrect. I have roughly 31 hours to solve this question until it is due. Can someone please tell me if the equations I am using are wrong and which equations I should be looking at?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Nov29-10, 11:04 AM   #2
Recognitions:
Homework Helper Homework Help
Can't be right - you need the charge on the proton multiplied by the charge on the nucleus. The 1/4(pi) doesn't look right either - you must mean 1/(4*pi*Enot).
Nov29-10, 11:13 AM   #3
Sorry for not including the brackets, I did mean 1/(4*pi*Enot).
So I changed the way I approached this question...below is my revised attempt which still ended up being wrong:
1/(4(pi)Enot) * (q oxygen * q proton)/radius min = 1/2 mv^2
9x10^9 (8*1.602x10^-19 * 1.602x10^-19)/(2.91x10^-15m +1.11x10^-15m)=1/2 (9.109x10^-31)v^2
9x10^9 ((8*1.602x10^-19 * 1.602x10^-19)/4.02x10^-15) = 1/2 (9.109x10^-31)v^2
4.5965x10^-13 = 1/2mv^2
1.00923x10^18 = v^2
1,004,605,104 m/s = v
This answer is incorrect. I decided to add the radius of the oxygen nucleus with the turning point radius as the radius between the two point charges. Maybe my radius should be something else but the way I did it seems right to me...unfortunately it isn't right :(
Nov29-10, 11:31 AM   #4
Recognitions:
Looks like you used the mass of an electron rather than the mass of a proton.
Nov29-10, 01:39 PM   #5
I recalculated by answer and used the protons mass this time. I had a final answer of 2344825.312 m/s which is still wrong. I don't know why the answer is not correct.
Everything else that has been inputted into the equations seems logical, I still must be missing something.
Nov29-10, 01:42 PM   #6
Ok, all is fine :)
I double checked everything, I must have missed a digit in one of my numbers the first time!
Final answer is 23448253.12 m/s and it is correct! Thank you for all your help Delphi51!
Nov29-10, 04:36 PM   #7
Recognitions:
Great; most welcome!
New Reply
Tags
fm from surface, oxygen nucleus, speed proton fired, turning point
Thread Tools
Similar Threads for: Nuclear model of Atom, O2 nucleus and speed at which a proton must be fired toward it
Thread Forum Replies
Energy to remove a proton and a neutron from a nucleus High Energy, Nuclear, Particle Physics 8
A Proton is fired from far away towards the nuclues of a mercury Atom Introductory Physics Homework 3
Proton fired at a nucleus Introductory Physics Homework 2
Proton vs. hydrogen nucleus Atomic, Solid State, Comp. Physics 3
Nucleus of atom High Energy, Nuclear, Particle Physics 27
