Volume of Revolution Problem: Calculating the Total Volume of a Haystack
  • Thread starter Thread starter tweety1234
    Revolution Volume
The discussion revolves around calculating the total volume of a haystack modeled as a solid of revolution, specifically using the function z = 2 - 2x², where z represents height and x represents distance from the axis of symmetry. The problem involves integrating to find the volume based on this function.
  • Participants discuss the integration process for volumes of revolution, questioning the need to rearrange the function for x and the implications of the radius in the volume formula. There are attempts to clarify the integration limits and the correct form of the integrand.
Several participants are exploring different interpretations of the integration process, with some providing guidance on rearranging the function and applying the volume formula. There is an ongoing examination of the correct setup for the integral, and some participants express confusion over signs and terms in their calculations.
Participants are working within the constraints of a homework problem, which may limit the information available for discussion. There are also indications of misunderstandings regarding the application of the volume formula and the integration process.
tweety1234
The height of an (axially symmetric) pipe z as a function of the distance from the axis of symmetry is [tex]z = 2-2x^{2}[/tex] , where both z and x are measured in metres, and where [tex]0 \leq z \leq 2[/tex] and [tex]0 \leq  x  \leq 1[/tex] What is the total volume of hay in cubic metres
in the haystack?
The correect answer is [tex]\pi[/tex]
I am told this is a volumes of revolutions problem, how would I go about solving it?
Not sure I know the equation for volumes of revolution is [tex]V = \int^{b}_{a} \pi y^{2} dx[/tex]
Any help appreciated.
solve for x in the z=2-2x^2 , and then you will integrate over dz and z will go from 0 to 2 , and when you do the pi(r^2) the square root will go away and it will be straight forward to integrate and you should get pi.
Thank you,
Just got a few questions, why do I have to rearrange for 'x'? Cause at first I thought of simply integrating z = 2 - 2x^{2}, I know z is the height and r is the radius, right?
[tex]\int^{2}_{0} -\sqrt{\frac{z}{2}} + 1 dz[/tex] Is this the expression I am meant to ingrate?
Also not sure what you meant by pir^{2} ? I know the volume of the pipe is going to be that of a cylinder sp, [tex]V = \pi r^{2} h[/tex], Am I meant to use this?
Close.. Try solving for x again.
[tex]x = \sqrt{- \frac{z}{2} + 1}[/tex]
Then, following the formula you provided, try integrating. Remember that this is the radius function, so you'll need to square it. The outcome should be directly integrable.
hmm okay, so I have [tex]V = \pi (\sqrt{- \frac{z}{2} + 1})^{2} z[/tex] so is this what I am suppose to integrate? from 2, to 0?
[tex]\int^{2}_{0} \pi (\sqrt{- \frac{z}{2} + 1})^{2} z dz[/tex]
Thakn you
Let's back up from the equations for a moment.
The concept of solids of revolution lies in the fact that the area of a flat disc is
[tex]\pi r^2[/tex]
When we take a function and use it as a boundary point, we are saying that the radius of out flat disc is equal to some function.
Integrating over
[tex]\pi r^2[/tex]
using our function as the radius gives us a volume.
So.. pi may be factored out as it's a constant. Leaving the formula.
[tex]\pi \int_{0}^{2} r^2 dr[/tex]
So, the squaring should be applied to the entire function that x is set equal to. Effectively removing the square root and leaving you with something simple to integrate from 0 to 2 that should evaluate to 1.. Which can then be multiplied by pi for your final answer.
Hope this helps
[tex]\pi r^2[/tex]
Integrating over
[tex]\pi r^2[/tex]
Hope this helps
I think have got it, but don't get the right answer, what am I doing wrong?
[tex]\pi \int^{2}_{0} \frac{z}{2} + 1 \\\\\\\\\\\\\\\\dz[/tex]
that gives me = [tex]\frac{z^{2}}{4} + z[/tex]
and evaluating that from 2-0 I get 3?
should be -z^2/4 you are missing A NEGATIVE sign in front of the first term.
oh right, I thought since your squaring a negative expression, it will become positive?
Thank you very much!
  • · Replies 20 ·
  • · Replies 27 ·
  • · Replies 105 ·
13K
