Interval of Convergence/radius of convergence
The discussion revolves around finding the interval of convergence and the radius of convergence for the series represented by the sum from n=1 to infinity of ((-5^n)(x^n))/(n^(1/10)). Participants are exploring the application of the ratio test in this context.
  • Participants discuss the use of the ratio test and the resulting limit involving |-5x|. Questions arise regarding the interpretation of this limit and how it relates to convergence criteria. There is uncertainty about the values of b and how they are derived in the context of convergence.
The conversation is ongoing, with participants attempting to clarify the implications of the ratio test results. Some guidance has been provided regarding the conditions for convergence and divergence, but there is still confusion about specific terms and the endpoints of the interval.
Participants are navigating through the constraints of the ratio test and the definitions of convergence and divergence, with some expressing uncertainty about the derivation of specific values related to the interval of convergence.
loganblacke
Find the interval of convergence of the series.. Sum from n=1 to infinity of ((-5^n)(x^n))/(n^(1/10)).
Find the radius of convergence.
Ratio Test -> Lim abs( (An+1)/(An)) as n goes to infinity
I used the ratio test to get to --> Lim as x goes to infinity of -5x(n/(n+1))^(1/10). I'm lost after this point. My notes say to use l'hospital's rule for infinity/infinity, which leaves me with the absolute value of -5x. plug that into the -b<-5x<b . How do you determine the value of b?
Thanks
I didn't check your work, but assuming it's correct so far, if the ratio test gives you a value of |-5x|, for what values does the ratio test tell you that the series converges?
I'm not sure where the |-5x| fits in but according to my notes the series converges if L < 1 and diverges if L >1. All of the problems that I have done so far have been -1 < x < 1 but i have no idea where the -1 & 1 come from.
Right. And you found that L = 5|x|. Putting this fact together with what you know about convergence and divergence using the ratio test tells you what?
OK so regardless of what L is equal to, the -b < x < b always start from b=1? In which case the series converges between -.2 and .2?? I don't understand the "b" part.
Forget the b.
You found that the limit L was 5|x|. The ratio test says the series converges if L < 1 and diverges if L > 1, so your series converges if 5|x| < 1 <==> |x| < .2 <==> -.2 < x < .2. The series may or may not converge at one or both endpoints of this interval. You need to check them separately.
  • · Replies 24 ·
